The manual on my CB360 says in the middle position there should be continuity between the red and black wires. Is this true? I have voltage on both but no continuity. I do have continuity between brown & brown/white though. Any insights?
Also, is it normal operation for the headlight to turn off in the "ignition" position of the switch?
edit: The only reason I ask about the continuity is the switch is BRAND new. Hard to believe it's bad.
