So I need the following for a 72 CB500:
-Kick spindle
-Kick pedal
-Points cover
-Alternator case (Not the exterior logo cover)
-Tachometer gear
-Headlight assembly
-Gauge set
The headlight is the same across the board so any CB headlight assembly will do, the points cover is the same for the 350F/400F/500F/550F IIRC. The other stuff has to be CB500 or K0-K2 CB550. Actually let me know if you have anything else 500/550 related, I probably can use it. Cheers.
-Kick spindle
-Kick pedal
-Points cover
-Tachometer gear
-Headlight assembly
-Gauge set
