CB vs. CL
Melbourne
So I'm totally new to this. I just bought my very first bike ever and I'm proud to say she's a 1971 Honda CL450 Twin. I'm interested in learning as much as I can about these great bikes and my first point of interest is the differences between the two models: the CB and the CL. Is one particularly better than the other? Is it possible to turn one into the other?
My basic understanding so far is that the main components are all very much the same such as the DOHC 444cc motor and carb setup. But for instance, the exhaust design is different and the front breaks are different. The CB uses a disc and the CL a drum.
Is there anything else majorly different about the two? Is the frame design the same? This is all the type of stuff I want to learn about. Any info anyone can give me will be a huge help in deciding where I want to take this new project of mine.
I believe the CL is geared a bit lower for more low end torque. Frame is the same but footpegs are different. CL is much more rare, especially if stock pipes are in good condition. Tanks are different. Either one is a good candidate for cafeing but CL's front drum brake looks more vintage but CB's disc works better.
CL's have high pipes, are geared a bit lower then the CB's, come with the drum
blah blah blah...
pretty much the same bike besides for the things mentioned above
good luck with The CL450- be sure to post pics; i dont see to many 450 CL's... ;) ;)
If you want a quick bit of info (plus a lot of interesting owners reports and trip write-ups) check out goodmotorcycles.com
I've used it for a while, its the online version of a once quite popular British bike magazine. Useful info in the 'Used Bike Guide' as well as the owners reports, I'd give it a check if only for curiosities sake.
Cheers - boingk
The only other differences I know of besides those mentioned above is that the stock handlebars have a cross-brace to make them sturdier (But you will be replacing those anyway right? ;)) and I think the rear brake pedal is different due to the different pegs. The CL is the scrambler version of the CB. It was designed for dirt roads and light off-roading, hence the lower gearing, high pipes, front drum and beefier handlebars.
Don't know if this is across the board or not, but my CL parts bike had front springs on the outside of the shock, covered by the gaitors. My CB of the same year has no external springs, but the same gaitors. Hence my question in this thread....http://dotheton.com/index.php?topic=9404.0
Nudge nudge wink wink
Oh, and I just completely disassembled my cl450 parts bike and the only noticeable differences were cosmetic. Side covers, tank, gas cap, fenders, etc. are all different. Seat is longer to acommodate the shorter tank (did someone already say that?).
