grapedrank
Brisbane - AU
I have a CB125 (bored to 150) engine that I partially disassembled to clean & paint. Bike is intended for race use only and has been used in the past as a bucket racer before I bought it.
I removed the stator/gen, cam chain and tensioner initially. Now putting the cam chain tensioner back together I have found I am missing the tensioner bar (part 6 in diagram). I didn't take any photos during dismantling of the engine though I do not recall seeing the part and it is not anywhere with the parts I have (I sorted all the parts in zip lock bags). On closer inspection of the rubber cam chain tensioner there are deep grooves carved into it at one end. I would suspect this is from being run without the adjustment bar at all.
I assume that when the tensioner adjustment bolt is tightened, the tension on the cam chain is relieved. I am after opinions on whether I need or should have cam chain tension adjustment, keeping in mind the bike is for race use only and will be mostly operated in the upper RPM range.
