CB125 first startup problems....
DirtbagUT
I finally got my 1980 cb125 started for the first time in about 13 years. I changed the oil and it started right up! My issue is that when im riding it at 1/4 throttle it goes just fine but anymore throttle than that it bogged down. I don't know how hard it is to tune the carb or rebuild it but Im thinking that it has something to do with the carb. If i cant figure it out I will be taking it to a shop but I would like to do the most that I can myself any ideas help,Also I don't have my battery in yet because it was getting charged if that matters
Sorry Im sure this question has been asked before but I looked and did not find anything :-[
Will not run right with out a good battery.
You do have a manual right?
sat for 13 years and you didnt open the carb?
Go though the manual it will all but walk you through getting it tuned.
have you checked the compression and points?
Sorry to be such a noob.
I NEED to get a manual ill open up the carb and take a look.
I have little to no knowledge if carbs/points. Im going to study up some more before I take the bike to a shop.
Could easily be a main jet is clogged up. At the bottom end of the throttle it's using the primary jet. As you open the throttle and raise the needle the main jet comes into play. If it's clogged, no fuel.
only order the kit form honda
Those cheap K&L kits are as useful as a screen door on a submarine.
Also it will not like to run without a good air filter. emgo pod is not a good filter
honda parts direct is a good source for parts online.
slow shipping some times but cheap prices
http://www.hondaparts-direct.com/fiche_section_detail.asp?section=119711&category=MOTORCYCLES&make=HONDA&year=1980&fveh=2868
so what numbers do I need to order. I know I dont need everything but I am not sure... sorry to be such a noob...
agreed, the fuel filter could be getting too dirty too. internal and/or external.
Also could be that your timing is out or the advancer is stuck. After all that sitting though, fuel issues as already discussed would be where I'd start.
Clean/rebuild carb
Check and Clean/rebuild petcock
Replace fuel Lines
Also be sure your tank is clean. If its still bogging move on to the points.
