CB125 s timing
While never having seen the end of the crank, there should be a "T" on it. Place the bike on the center stand, pull off the generator cover (it will drip some oil - put down a drain pan) and hold the plug to the case. Rotate the crank by hand til the spark is lit in line with the T.
Be sure to look for a manual from DTT's home page and welcome to the site!
Line it up with 'F' (fire)
'T' is top dead center
There are two 'vertical' lines which should more or less line up at full advance.
Rich, it's just about exactly the same as a CB350/360/450 except there are only one set of marks instead of left/right (think half a CB250 twin :D)
