CB160 / First time owner - Long Beach, CA
shaneofstrength
Hey Everyone... Been a reader for awhile, mostly since purchasing first bike back in January. 1966 Honda Cb160.
Like many first posts, I waited until I had a problem I just couldnt diagnose.
Basic problem is that I can ride for a few minutes, then engine starts to die out. More gas just makes it slow, and it chokes up until dead. After a few minutes (3-5) I can play with choke, get it running, and repeat the process.
Questions:
-The bike appears to have two different carbs. Both are Keihin, and same size, but seem to be a bit different in jetting locations, possibly manufactured different years. Does it matter? All jets are same size... 92 for main, 38 for slow.
-The gas cap is old and rubber is showing age. It's possible it isn't perfectly airtight. Is this an issue?
-Air filters and exhaust are after market. Air filters have cracks in rubber boots, and front left exhaust small leak. Investigation shows the flange that mounts to head was eroded. I'm trying to find original pipes, but cannot afford at this time. Any options sitting around?
-Oil appears a bit dirty. Engine calls for SAE 30 (stamped on casing) in this weather. Would you recommend using something else on an older engine, adding Lucas Oil, etc? One mechanic told me 10w40 motorcycle, but I'm looking for any other opinions. Mileage is just short of 16k (not sure if 100% accurate). I've also heard suggestions for fuel stabilizer. I'm using Chevron 87 currently without additives (aside "techron").
-Engine seems to have trouble recharging the battery. If I ride it around all day, electric starter dies. I don't mind kick/push starting, but am wondering what issue is there. If I keep a drip charge it always starts right up, but curious what the cause is. I understand there are some rectifier replacements. Wondering if anyone else would recommend this. Battery is fairly new, and at about 90% health.
Any thoughts, recommendations are appreciated. Main concern is money. I have a wealth of time, but not much money, so trying my best to learn the bike, and fix things myself.
Thanks,
Shane
Here is an image of the bike. Looking forward to some summer rides.
I think the best thing to start with would be the factory service manual, you've listed so many things there that I don't know where to start really... at that point, could be electrical, fuel/air, lots of things... service manual will help, especially if you have the time to read it, and it helps save money too because you're not throwing parts at the wrong problem
That's a clean little bike.....
I don't know why the carbs would be different, but as long as they are the same size, they should be good.
Don't worry too much about that rubber seal for now - it just prevents gas fumes from escaping. The actual vent is a small hole in the center of the underside of the cap.
Forget about fuel additives. Just keep running fresh gas thru it. As far as oil goes - follow what's in the manual for your temperature. As long as the oil is designed for wet clutches, you'll be ok. Since there's not an actual oil filter on that motor, it's important to clean out the oil often (drain / replace / clean out the oil "trap" on the right side).
Charging problems can be a little tough.....could just be some dirty connections from the stator. I don't think the 160's have a regulator - just a rectifier. Right?
Thanks for the replies everyone. Tracked down a manual for the bike, and did my best to read through everything. Watched a buttload of youtube videos on parasitic draws, etc. and have been poking around with multimeter to no success.
Since last post i went ahead and got some new air filters, as the last were pretty badly cracked, and too small for the carb. K&N fit nicely, but unfortunately didnt change much to original problem. Changed out oil (unfortunately not centrifugal filter as bolts are stripped - need extractor).
Unfortunately, same issue with running... then dying, more quickly lately. I've also, changed plugs, de-rusted tank, fixed neutral light, purchased/installed rectifier from http://www.oregonmotorcycleparts.com and am planning to go through timing, points, and valves... as soon as I feel confident enough to do so. I hear with these older bikes, timing may be everything.
Thanks again for comments. Wish me luck.
I'm going to sound like a huge prick here, but it sounds like this bike has been unattended for quite awhile and needs a multitude of work to get her right, and this isn't even accounting for compression checks etc. If $ is an issue, I'd sell the bike, these bring good $ even in none running condition and would probably bring in enough to buy a running better condition bike.
Now... The 160 is a really neat little bike, and we've all been where you're at $ wise, and if you want to keep this bike, you're going to have to set some type of priorities to get her back where you'd like her. First, any hobbies you don't partake in anymore and still have all the equiptment? Sell it. Drink? Drink less. Smoke? Smoke less... Any of your buds have side work you can do? When it comes to bikes, there's been times I've sold my cars, watches, guns or anything I'm not using, to get them right. And of course you already are doing a lot of your own work on the bike.
In the Honda world, you have one of the holy grails of bikes. She is history and deserves attention. Has the head been done? 87 is going to eat the valve guides. You have one of the neatest little bikes ever made, I'd make a list and start going through it and make it right. there are about a million guys waiting for you to lose interest in that bike so they can get their hooks on it. Good luck, I'm one of the guys who let one of those get away decades ago and wished I had it back...
Haha. Thanks for the motivation ApriliaBill. It wasn't so long ago this beaut' was running actually, she just never really hit her potential as far as I realize, and a few months ago just came down with some things that are symptomatic of a handful of problems. Likely just one, but gotta go through and figure out.
I was able to track down the owner, two owners back, and seem to have a better idea of what's happened between then and now, and what/where work has been done. The person I bought it from moved to Barcelona after visiting for nearly 8 months (bike sitting that whole time).
Care to elaborate, or link to existing post on 87 fuel? I've heard (and i know we ALL hear things) that if the bike wasn't made when there was higher octane fuel, you shouldn't use it. This runs contrary to what i've heard about oil. Most folks recommend 20w50 (Motul if you can find it) over the old SAE20 or 30.
I'm just trying to learn as much as I can, because I' fascinated with the old machines, and don't want to do more damage than good.
Shane, gas back then had lead in it and was much higher octane, along with the chemicals they put in todays fuel that actually attract water, just ask guys with Italian bikes. Without the lead, the valve guides go to hell. Most people I know with bikes as old as your's either have the heads redone and the guides replaced to run on todays crap fuels or use lead additive, which on Cali is illegal. You have a gem sir, I hope she's back and running soon, those bikes sing....
