cb160!
Curbcast
Over 1,000 Posts
Today I picked up a 160. Complete, though quite a project. The engine needs work. Its been bored & has new pistons, but no rings.
Rims are shot.
Cases are pretty clean
Hubs are clean
Headers alright
Tank pretty good.
Frame good.
I love the hubs on this thing. They are huge!! Theres not many 160s on here. Though I wish there was, cause Imma need help when this all starts up as a thread.
Later dudes
Now that I got home and looked at it on my computer, I'm really jealous!
I'll extend you the same offer - any small parts you might need, just let me know. I'll try and hook you up
Heres my main inspiration. I mean shit, this bike is gorgeous. I wanna do EXACTLY that. But wont, as thats copy cat.
Maybe a fairing. I dont know yet if theres 160 race clubs in this area.
I believe you are going to have to measure the bore of the jugs. Find what diameter they are originally and see how much bigger it's been bored out.
Correct?
http://cgi.ebay.com/ebaymotors/Honda-CB160-CA160-CL160-CB-CL-CA-160-piston-ring-set-50_W0QQcmdZViewItemQQhashZitem19bab7426dQQitemZ110506754669QQptZMotorcyclesQ5fPartsQ5fAccessories#ht_500wt_1182
think thats what I need. Just based on the fact that it has a .5 on it. haha
Stock bore is 50.0mm, so 50 means 0.5mm oversized = 50.5mm bore. Easy.
You really need to measure teh bore for wear to be sure that the pistons are the right size for the bore. A quickie way is to insert a feeler gauge between the bottom of the piston and the bore. It should be between 0.015" and about 0.030". Much more than that and it will be noisy.
The rings you want are 0.5mm oversize. The parts book will give you the correct part number.
Thanks for the offer 'again' BigR. The 175 and 160 fit similar? I need 2 tappet covers. The 160 looks smaller then 175 though.
VonYinzer, found the build info on that bike:
http://www.thebenlyshop.com/ Shop/builder
http://www.motorcycleclassics.com/Motorcycle-Reviews/September-October-2008/Honda-CB160.aspx Write up
http://guywebster.com/ Owner
Says it cruises nicely at almost 100MPH. DOTHETON!
Heres a photo of my two motors compared. Very similar & most of the covers match right up. Did not know that. Im geussing my rear sprockets will match up too. Super cool that I just got that 175 parts bike. Will be put to use.
Also in photos attached it shows some fin damage. This little fish has seen battle. Im way to picky to let it slide, so Im on the hunt for new jugs.
I measured my cylinder with calipers & its reading alittle over 50mm. Cant really get a super defined measure, but the .5 pistons slide in.
Cool
Ya know, with a little bit of research, might find out that a lot of parts can be swapped from the 175.
