cb160!
or not, as the case may be.
Quite a few parts are interchangeable, but it won't look like a CB160 motor. If that's OK then swap out the whole top end, have the cases welded and machined for the 5 speed cluster on the 175 and enjoy the extra cubes. better to replace the exhaust valve guides with CB200 items with oil seals though. And upgade teh oil pump while you are in there.
Or just have the fins repaired - easy, and fit rings or ....
bore it for larger bore pistons and leave it looking stock on the outside. There are CB160 motors with 56mm and larger pistons and hot cams and larger valves and they look stock on the outside. There are others with 61mm pistons, 240cc and CB200 top end with all manner of different pistons.
Slip in new liners and larger pistons with custom machined crowns, maybe weld up the combustion chamber for higher compression and a different flow pattern. maybe try a 180 degree crank and custom reground cam with 26mm or 28mm carbs and custom intake manifolds.
And those are just the bikes we built. heaven knows what anyone else has been up to. ::) ;D ;D ;D
Start with the end in mind. Work out a plan and try to stick to the plan.
Teazer dont tease. Haha, all that tech stuff you just spewed freaks me out. Im want to go back to stock I think. Like I said its .5 over now, but my cooling fins are damaged, & I wanna fix that. Aka get a new top end.
Have any leads on parts motors etc?
You should show some pics of the bikes youve done. Thanks for the input!
Where can I find good info on these bikes? Caferacer.net has some builds. I found a good one on Adv.rider
Im on yahoo f160 too.
Just spent the morning getting titles.
1 for my 175 build.
1 for my 175 parts bike.
1 for the 160.
Im super stoked. $10 bucks for an afadavid (holy fuck bad spell attempt)
