CB175 Cafe W/ more pics
whats up.
love that you want to race it!!
i want to do the same thing with mine. have you done any thing to the motor, other than carbs???
i saw the vid, and love the sound! i to want to run with straight pipes, my mufflers have removable
baffles. really like the build and hope mine turns out like this..
later.
cheers.
supercafe said:
whats up.
later.
cheers.
Thanks alot... As far as internal mods to the motor go. I have'nt touched it... The early 175's have a much higher lift cam and a bit more comp(which causes alot of problems) than the later models. Mine is a 70' motor. And produces 25bhp stock(full exuast, factory filters and jets ect). Which we all know isnt alot. But when the bike is under 200lbs. your looking @ a real decent hp to weight ratio. Where as say a 76' cb200 produces a much lower # @ 17bhp...< And thats slow!
Bateman racing makes anything you'd want high cop. pistons, race cam, bigger valvles, machine work ect. But you have to be carefull, because most of the classes for these do not alow such mods. They try to keep it fair, so it's not a money game. Even the rich guy has to know how to ride.
Hey Louie -
If I haven't said already (multiple times) I totally dig this bike - it looks completely awesome.
I'm in the market for a bike that I can ride for the majority of my commuting (I'm a designer, so I need to be able to meet with clients). But I really like the idea of running a lighter bike, for agility, and ease of handling.
One thing that I'd like to do with whatever bike I get is follow the Lotus formula - "Simplify, and add Lightness" - I'd rather get a high horsepower/weight ratio by having a low weight vs higher horsepower. But I also want a bike that is going to have enough power to get me where I need to go. Mind if I ask how tall/heavy you are, and how you feel the 175 works for you in that relation? I'm looking more at the 360/450 range right now.
andrew embassy said:
Hey Louie -
Looks like you answered my question about size in the other forum - thanks!
Hey Louie -
As a 175 owner I could tell you that it's a fun bike, but mostly for city driving or twisty mountain roads. If you are light enough and it's in the right state of tune, it will go up to 80mph, although it's not comfortable at anything over 60mph. The engine will be screaming at 8000rpm, and hills / headwinds will be like hitting a wall. It will do bursts of high speed, but I wouldn't drive mine for hours on end at highway speeds. It just doesn't have enough torque to push through the drag at higher speed.
You'll also realize that the faster you go, the less likely the cable operated drum brakes of fury will be able to stop you. At lower speeds this is fine.
This bike is designed for acceleration, revs and handling. In the city it's a great deal of fun because you can use the whole rev range and the power to weight ratio is pretty good, 270 lbs for 22hp, that's about the same as a sports sedan (say 2700lbs, 220hp). The gearing is really aggresive and brake fade is not as much of an issue at lower speeds.
But the best thing about the 175 is that you can ride like a madman all day and still get 80MPG.
Yeah - it's seeming that I'll probably want something larger; right now I'm looking at a CL350 which might do the trick- if I lighten that up it might be a good compromise. Anybody got ideas on how to lighten a 350?
I have to disagree w/ alot of this... Its way comfortable @ any speed. And will do 90mph when dialed in (Way faster than I need to go). And 8000 rpm isnt screaming for this motor. 8000rpm is when mine wakes up...It is the highest reving twin honda ever produced. red lining @ just over 10,000 rpm stock. And with minor porting, jetting and timming adjustments will go 11,000 rpm. Vent your brakes and you wont have to worry about brake fade. It is far from a "freeway flyer". If your a fat ass, this isn't the bike for you. And find me a sports sedan that ways 2700 bls. My acura TL is like 4000 @ 230hp. And it hauls ass! Youll never get 80mpg either. If you Ride this bike, your gonna get closer to 30mpg.
A few questions here because I was looking to do something similar.
-I'm wondering how you attached that seat?
-I understand you're planning to race, but what if you wanted to work in a stand with that belly pan? Would the center stand still work if you cut out the back of the pan? I think the kickstand is way out of the question, right?
-Won't the pan wiggle around a bit on the road if you use zip ties? What about using pipe clamps instead?
The seat is kinda rubber mounted... With button head allen bolts. No, the center stand wont work w/ the belly pan. I plan on fab'n up some sort of fold-able kick stand that will fit in the end of the rears-set. Maybe stash it up inder the seat. The belly pan is notched to fit.Both sides of the frame are different. It fits like a puzzle piece. This bike isnt going to see a whole lot of communting. Weekend blast through the mountains w/ some freinds is about it. And in that case. I'll lean it on a tree :)
hay man.
got a question????
can you take some close ups of your rearsets and how they are mounted, etc.
just got mine from leon, and what to install them, my frame is the same as yours.
would be appreciated.
any more resent pics of the bike, tires, paint etc.
any way, can't wait to see the finished product.
cheers.
supercafe said:
hay man.
got a question????
cheers.
Ya, sure ....I'll have to take some closer pics. In the next day or so. I keep the bike @ work so I cant go out and snap some pics right now.
With all due respect I rode my CB175 5000KM last summer and averaged between 70 and 80MPG. A lot of the driving was going flat out on country roads going about 75mph. If you are only getting 30MPG out of yours something is really off. I would fuel up every 100 miles and put about 5L of 91 octane in there. That's about 1.25 gallons.
I'm not gonna argue w/ you. But, your #'s are + 30mpg of what the manufacture quotes. Maybe it's the air over there? ::)
CA160 (1967 - 1970) - Fuel Economy Range: 68 to 81 mpg - 29 to 34 km per litre - 3.5 to 2.9 litres per 100 km
CA175 (1968 - 1970) - Fuel Economy Range: 67 to 80 mpg - 29 to 34 km per litre - 3.5 to 2.9 litres per 100 km
CB160 (1967 - 1970) - Fuel Economy Range: 68 to 81 mpg - 29 to 34 km per litre - 3.5 to 2.9 litres per 100 km
CB175 (1969 - 1973) - Fuel Economy Range: 70 to 83 mpg - 30 to 35 km per litre - 3.4 to 2.8 litres per 100 km
CB200 (1973 - 1978) - Fuel Economy Range: 65 to 77 mpg - 28 to 33 km per litre - 3.6 to 3.0 litres per 100 km
CB200 (1974 - 1976) - Fuel Economy Range: 65 to 77 mpg - 28 to 33 km per litre - 3.6 to 3.0 litres per 100 km
CB250 (1964 - 1974) - Fuel Economy Range: 62 to 74 mpg - 26 to 31 km per litre - 3.8 to 3.2 litres per 100 km
CB250 Nighthawk (1991 - 2000) - Fuel Economy Range: 65 to 77 mpg - 28 to 33 km per litre - 3.6 to 3.0 litres per 100 km
CB250GS (1968 - 1973) - Fuel Economy Range: 67 to 80 mpg - 29 to 34 km per litre - 3.5 to 2.9 litres per 100 km
CB350 (1968 - 1973) - Fuel Economy Range: 49 to 58 mpg - 21 to 25 km per litre - 4.8 to 4.0 litres per 100 km
CB360 (1974) - Fuel Economy Range: 64 to 76 mpg - 27 to 32 km per litre - 3.7 to 3.1 litres per 100 km
CB360G (1974) - Fuel Economy Range: 64 to 76 mpg - 27 to 32 km per litre - 3.7 to 3.1 litres per 100 km
CB400A (1978) - Fuel Economy Range: 44 to 52 mpg - 19 to 22 km per litre - 5.3 to 4.5 litres per 100 km
CB400C (1982) - Fuel Economy Range: 50 to 60 mpg - 21 to 25 km per litre - 4.7 to 3.9 litres per 100 km
CB400T (1980 - 1981) - Fuel Economy Range: 47 to 56 mpg - 20 to 24 km per litre - 5.0 to 4.2 litres per 100 km
CB400T Type I (1978 - 1979) - Fuel Economy Range: 47 to 56 mpg - 20 to 24 km per litre - 5.0 to 4.2 litres per 100 km
CB400T Type II (1978 - 1979) - Fuel Economy Range: 47 to 56 mpg - 20 to 24 km per litre - 5.0 to 4.2 litres per 100 km
CB450 (1965 - 1974) - Fuel Economy Range: 48 to 57 mpg - 20 to 24 km per litre - 4.9 to 4.1 litres per 100 km
CB450T (1982) - Fuel Economy Range: 54 to 64 mpg - 23 to 27 km per litre - 4.4 to 3.7 litres per 100 km
CB500T (1975 - 1976) - Fuel Economy Range: 50 to 60 mpg - 21 to 25 km per litre - 4.7 to 3.9 litres per 100 km
CD175 (1968 - 1970) - Fuel Economy Range: 67 to 80 mpg - 29 to 34 km per litre - 3.5 to 2.9 litres per 100 km
CJ250T (1968 - 1973) - Fuel Economy Range: 67 to 80 mpg - 29 to 34 km per litre - 3.5 to 2.9 litres per 100 km
CJ360T (1976 - 1977) - Fuel Economy Range: 62 to 74 mpg - 26 to 31 km per litre - 3.8 to 3.2 litres per 100 km
CL 160 (1967 - 1970) - Fuel Economy Range: 68 to 81 mpg - 29 to 34 km per litre - 3.5 to 2.9 litres per 100 km
CL125A (1967 - 1969) - Fuel Economy Range: 77 to 92 mpg - 33 to 39 km per litre - 3.1 to 2.6 litres per 100 km
CL175 (1969 - 1973) - Fuel Economy Range: 70 to 83 mpg - 30 to 35 km per litre - 3.4 to 2.8 litres per 100 km
CL200 (1974) - Fuel Economy Range: 61 to 73 mpg - 26 to 31 km per litre - 3.9 to 3.2 litres per 100 km
CL250 (1967 - 1974) - Fuel Economy Range: 62 to 74 mpg - 26 to 31 km per litre - 3.8 to 3.2 litres per 100 km
CL350 (1968 - 1973) - Fuel Economy Range: 49 to 58 mpg - 21 to 25 km per litre - 4.8 to 4.0 litres per 100 km
CL360 (1974 - 1975) - Fuel Economy Range: 60 to 71 mpg - 26 to 30 km per litre - 3.9 to 3.3 litres per 100 km
CL450 (1968 - 1974) - Fuel Economy Range: 47 to 56 mpg - 20 to 24 km per litre - 5.0 to 4.2 litres per 100 km
CM185T (1978 - 1979) - Fuel Economy Range: 67 to 80 mpg - 29 to 34 km per litre - 3.5 to 2.9 litres per 100 km
CM200T (1980 - 1982) - Fuel Economy Range: 66 to 79 mpg - 28 to 33 km per litre - 3.6 to 3.0 litres per 100 km
CM250C (1982 - 1983) - Fuel Economy Range: 62 to 74 mpg - 26 to 31 km per litre - 3.8 to 3.2 litres per 100 km
CM400A (1979 - 1981) - Fuel Economy Range: 46 to 55 mpg - 20 to 23 km per litre - 5.1 to 4.3 litres per 100 km
CM400E (1980 - 1981) - Fuel Economy Range: 52 to 62 mpg - 22 to 26 km per litre - 4.5 to 3.8 litres per 100 km
CM400T (1979 - 1981) - Fuel Economy Range: 52 to 62 mpg - 22 to 26 km per litre - 4.5 to 3.8 litres per 100 km
CM450A (1982 - 1983) - Fuel Economy Range: 42 to 50 mpg - 18 to 21 km per litre - 5.6 to 4.7 litres per 100 km
CM450C (1982) - Fuel Economy Range: 54 to 64 mpg - 23 to 27 km per litre - 4.4 to 3.7 litres per 100 km
CM450E (1982 - 1983) - Fuel Economy Range: 54 to 64 mpg - 23 to 27 km per litre - 4.4 to 3.7 litres per 100 km
CM450SC Nighthawk (1982 - 1986) - Fuel Economy Range: 50 to 60 mpg - 21 to 25 km per litre - 4.7 to 3.9 litres per 100 km
CMX250C Rebel (1987 - 1987 & 1996 - 2003) - Fuel Economy Range: 56 to 67 mpg - 24 to 28 km per litre - 4.2 to 3.5 litres per 100 km
CMX250CD (1986) - Fuel Economy Range: 55 to 65 mpg - 23 to 28 km per litre - 4.3 to 3.6 litres per 100 km
CMX450C Rebel (1986 - 1987) - Fuel Economy Range: 55 to 65 mpg - 23 to 28 km per litre - 4.3 to 3.6 litres per 100 km
SL175 (1970 - 1971) - Fuel Economy Range: 66 to 79 mpg - 28 to 33 km per litre - 3.6 to 3.0 litres per 100 km
SL350 (1969 - 1973) - Fuel Economy Range: 49 to 58 mpg - 21 to 25 km per litre - 4.8 to 4.0 litres per 100 km
