pacomotorstuff
Coast to Coast
Hi everyone,
Continuing the trudge on the Dad 'n Daughter Tiny Tracker, I'm reassembling the head after new guides, seals, valves, springs, retainers - brought it as close to brand new as I could.
Anyway, with the camshaft in the head and the 2 camshaft bearing plates torqued down, I measured .025" - ie, 25 thou end play in the camshaft, moving it back and forth across the head, if you will, using a feeler gauge. The bearing surfaces in the endplates are good, there is no evidence of the either end of the cam wearing on their respective cap and the cam doesn't have any slop when rotated - just back and forth across the motor.
Never worked on a CB175 before and wondered whether this is normal - maybe to let the cam sprocket line up with the crank sprocket or something (I haven't put the head on the motor yet, so don't know about camchain alignment).
The manual I'm using, makes no mention of this, so if someone could let me know, that'd be great
Thanks,
Pat
Thanks,
Pat
