cb175 carb help
pat_00
Just got this bike: http://dotheton.com/index.php?topic=7616.0 Trying to get it running
The previous owner changed the accelerator cable, and afterwards it wouldn't start. I've had a quick look, but can't fidure out what he's done wrong. It has compression and the sparkplugs are firing. Any suggestions as to what to check?
does the throttle work properly? are you sure that the throttle cable is the reason it isn't starting?
i'm no expert but that's where I'd start. After that pull the plug wires and check for spark. if you've got spark, then check the air filter to make sure she's getting enough air.
If you've got spark and air, then it's a carb issue. fun.
post up what you find
Have you checked the timing? You may be getting spark, but is it at the right time?
thanks for the tips, will do the timing, tappets tomorrow see if that helps.
otherwise i'll pull the carbs down.
Okay, had a quick tinker last night.
Unfortunately i have no room to work on the bike here, and have to travel to my brothers' house everytime, so i can't just run out and have a look.
I checked the spark plugs which are fine, gap was perfect.
However when I went to do the timing, I removed the left side crank case to find the whole area inside drenched in oil, which worried me. I checked the oil, and it had a petrol smell and was quite runny.
Unfortunately i ran out of time and had to leave, before i could do anymore.
What i think has happened is petrol has leaked into the oil, diluted it and made it seep through the leftside crank seal. But, what would cause the petrol to get into the fuel in the first place?
Any ideas?
