Cb175 engine drama
beaver
Hi everybody
My cb175 started squealing somewhere in the engine, after I stopped it didn t want to kick start, i try to bump start it and finaly did after few tries. It stalled sudently and i coudln t move the kick stArt at all, when trying to bump start the back well would just lock and not turn the engine.
I thought SEIZED engine, but this morning I went to pick the bike and the engine spins when kicked, i did not try to start it but has it doesn t feel right in there.
Where should i start and what possible drama can i expect?
Piston, cylinder....
Cheers
Jb
So I remove the engine of the bike, I pulled the cam cover off( if that s even the name) everything looks normal as far as I can tell I pull the timing cover off and the engine spins freely.
I am gonna study the haynes book I have and see what I can figure out.
could it be possible you pushed the engine a bit too much and the piston got stuck because of heat-expansion. The engine cooled down and piston is free again. check for scratchmarks inside your cylinder. you can check this a bit by using a flashlight and watching through your sparkplug hole...
Wrong type, wrong weight or wrong amount of oil.
Moving too slowly for too long of a time frame can overheat them really easily.
Those seem to be the most common causes of temporary lock ups. Consider yourself lucky, my 1963 Honda is locked up tight, something in the transmission is stuck. Been too busy to open it up.
It s true that the oil seems to have lost its viscosity, it s really runny. I ll try to see if the piston is damage.
The right side of the cam where the valves run was dry, could be where the squeaking came from?
Thanks a lot for all the advices and comments
did it have excessive valve clearance ? but when you get the cam out it should fit the journals/bushings nicely, they dont allow for much running clearance and if they have seized you will see evidence of that
good luck i hope it aint too bad !
So i pulled the to end apart,
Pistons and cylinders are fine ;D
I adjusted the valves, points, timing and everything as per the manual,
Reassemble the bike, first kick and it came to life like never before
UNTIL
same squealing noise came back bike stoled and can t move the kick anymore, so I believe it comes from the tacho side of the cam, i removed the inner gear of the tacho ( the one that get driven from the cam) could that be the cause of my problem ? Does it act as a bush / guide or something?
not enuff information from you
did you check the cam bushing clearance ?
what kind of shape were those surfaces in? camshaft journals and bushing surfaces
did you set and or check the camshaft endplay/axial clearance?
Sorry mate, my knowledge is very limited, I learn as I go... Hopefully I learn a bit
Well i found the problem thank you for pointing me right way, there is a small sleeve that fit between the cam shaft and the tachometer gear that i didn t see when removing the gear, it got jammed.
I created an issue by not looking properly when removing part.
Bike runs great and all previous issue have disappeared ( hard start miss-fire backfire...) all gone thanks to valve clearance and timing done.
Thanks again everybody
