hello all
for those of you who read my intro you know that I bought a 71 cb175 about a week ago, for those of you who didnt read my intro, well, I bought a cb175 last week.
so here is where it is right now
I finally found the time do do the work on it. got the carbs cleaned, adjusted and synced. took it down the road a few times and am able to get about 62mph out of it at 9k in forth. after that the steering gets a bit wonky (40 year old tires )
I do need to change out the mufflers as they are from an unknown source and leak quite a bit at the header junction.
after getting back from the from the test I noticed a little smoke coming out of the left pipe. at idle it is not much, almost imperceptible, but when I give it the beans it gives a good sized puff.
I also noticed that it does seem to have a bit of oil coming out of the left intake valve adjustment porthole (with cover on)
the rt sparkplug is perfect, the left is slightly wet
spark is good, new plugs.
I have not done a compression check as I cannot figure out who borrowed my compression tester and never gave it back
I have not checked the valve adjustment yet as I dont not have the specs on the settings yet.
I was told that it did have the rings replaced about a year ago, and the compression was supposedly at 170 for both cyl at W.O.T. (unverified)
I know valves and seals are semi-common on these engines, but before I start to do a teardown I was wondering if anyone has any suggestions
I do not have the time to do a teardown on the head so I will most likely end up bringing it to someone local if it needs that (any suggestions for northwest illinois would be appreciated)
any guesses would be great
Thanks in advance
M.J.N.
Thanks in advance
M.J.N.
