cb200 2 into 1 exhaust question
stik70
Coast to Coast
I want to build a 2 into 1 system for my cb200. Stock header pipe size is 1 3/8" and i have a set of mcm header pipes for a different honda that are 1 1/2" o.d. which i want to transistion to. Meg's exhaust shows 2 into 1 collectors with different sizes of outlets available. Can anyone help me out with what the best size header pipe, lengths, and outlet size to get the best performance. I want to build a reverse cone megaphone. Am i barking up the right tree? I want it to resemble the predator exhaust system offered in the UK. Thank you in advance for any technical advice or formulas you might have.
Stik
correct size is about 3/4" to 1" diameter.
You probably NEED about 5/8" to 3/4" inside diameter
Stock pipes are dual skin, the inner is much smaller diameter.
If you take a look at new Kawasaki Ninja 250 you'll see how small pipes should be for max performance. (with ~125cc per cylinder)
1.5 inch is massively too big, that's the size I have on XS650 with 325cc per cylinder (OUTLET on my CB378 after collector is also 1.5")
PJ
from what i am reading on theory, the 1 1/2" OD header pipe IS too big. It would take away from the low end and midrange, which is not what i want.
Stik
