cb200 alternator in cb550
Bert Jan
Holy Modification Batman
I want to convert a cb550 engine to run without battery.
Reasons are reliabity, lighter 'flywheel' for aggresive throttle response and because loads of companies/people say it can not be done on the cheap.
As the oem field rotor needs current to deliver current, it has to go.
i have a spare cb200 engine and it so happens to have an magneto rotor that fits on the crankshaft. Good.
I made an alumium bracket to support the coils to the engine;
and voila;
She runs on it, without a battery, using the pink and yellow wires to power the coils with an diode bridge. I can even run dual 55 watt lamps on 1500 rpm (with an regulator in between) and she won't even sputter. Very very fast throttle response :) me likey.
But..... she wont start on it, she needs battery to start.
When she runs i can detach the battery immediatly. Ideal for racing, but not so ideal for commuting. My question is: why can a cb200 start without battery and a cb550 not, and why can she run without a battery but not start? Is it purely a power thing (the alternator cant give 2 coils power when kicking) or am i missing something?
i also jumpstarted her with the startermotor straight on a car battery, for added rpms during startup, but that did not do the trick either. no spark.
Then, while running it on startermotor (i know its bad for the startermotor but i have 4 so dont care, price of progress :P) i attached a small 2 amp battery and braaap she fired up imediatly. im in the dark, please help.
You need a capacitor.
Without a way to store charge you're out of luck.
It will take a few kicks to build the charge and then it will fire up.
Get a 15,000 uF capacitor and put where the battery would be and it will start.
Ok, sounds logical. But why does a cb200 not need a capacitor or battery?
Edit; what voltage should the capacitor be? I see 40v, 400v and so on. What does it do anyways and why does a 200 not need one?
In the simplest terms a capacitor is essentially an instantaneous battery. It "stores" charge, so when you kick (which you have already found is not enough juice to make a spark) it saves it up until it is enough and then bam spark.
As for why you don't need it on the 200, I would guess that the electrical draw on the 200 is much less than that of the 550 so the coils don't need as much juice to fire, so the stator produces enough power to make a spark.
And the 40V should do the trick.
Also you posted a thread not too long ago about a cb200 not running without the battery haha so I'm a bit confused
Grab your multimeter and attach it to your stator after the rectifier and regulate and see what kind of voltage it's putting out when you kick it
Whoa! Good memory! The 200 thread was solved by replacing the rectifier. It was faulty. It runs now without battery. Essentialy, when i disconnect 1 coil on the 550 the other one should spark, as the 200 also has 1 coil with 2 plugs. Ill try the capacitor trick and report my findings.
Are these units prone to failure, because when they are, its not a reliable solution.
I forgot to tell the cb550 will bumpstart with the 200 rotor and no battery. Have to run like hell though ;) so thats another brick in the wall for the "lack of juice" theory.
Okay in that case yeah you're just not generating enough voltage from the stator to fire the coils until you hit idle rpm.
An a capacitor is solid state and unless you crush it or break off a terminal it will work indefinitely, no chemical reaction to deplete like a battery. It's basically two metal plates with a small gap that the creates a charge differential to ground (voltage) , allowing you to store electricity momentarily.
Aight! out to buy one and report! Last question: how does the capacitator know when to release current?
You know I have really never thought that one out in the context of motorcycles!
It should work as follows:
when your stator rotates, the charge flows directly to your coils and say you're putting out 10V, 10V won't make a spark.
But with a capacitor at least some (probably half) of that voltage flows into the cap, and in the time it takes the coils to discharge and "fire" (even with the insufficient 10V) the capacitor was absorbing energy from the stator, so that on the next spark cycle you have the 10V from the stator plus however much the capacitor was able to store while the coils were firing. So on the second go round (I think it's more than 2 actually) you have enough to make a spark, which fires the cylinder propelling the stator faster and bumping it up to a voltage that can sustain running.
( you can only kick it a couple hundred Rpms)
On top of that a capacitor acts to "smooth" the output from the stator as it absorbs the overcharging and releases the energy when there isn't enough charge. This is what a capacitor is generally used for.
You'll notice on your 200 running without a battery that the lights will flicker slightly at idle, a cap would take care of that
just what i needed. thanks a bunch!
It doesn't 'release' the stored current...think of it as a bucket with a tap in the side. Someone else has to open the tap. In this case, it will dump any stored current as soon as there's a draw on the system.
Dont get it. Theres a draw on the system the moment i kick it because the coils use all the current provided right? fire or no fire, the coils eat all the juice away?
Well your coils only fire when the points open right? So in the mean time ( which doesn't seem like much to us but to an electron it's an eternity haha) the capacitor has time to charge (or store electrons) , and then there's a "draw" again as the coils fire (or charge really).
Wich means one kick would be sufficient?
Probably not I couldn't tell you on your bike too many variables!
What you can do it turn the kill switch off (it supplies power to your coils) and then kick it a few times to charge the cap, then flip the switch and start her up. And this all assumes you have a good running bike to start with of course
Get you one a play with it :)
killswitch? hehe..... my wiring loom has 2 wires. A black one, and a green one. If i kick her with the key off, current will flow in the capacitor. so that would be the same as the killswitch option.
