CB200 Engine help
motorcycleman03
I have a 1974 cb200 i am in the process of fixing it up. I had oil coming out of my exhaust. what does this mean? Does this mean i need new piston rings? or maybe something with the valves or how can i tell?
First things first, make sure the tappets are adjusted properly. You haven't pulled the motor out recently, have you?
Once the valves are adjusted, do a compression test. If you get low numbers, add a little bit of oil into the spark plug holes and then do another compression test. If the low numbers stay the same, it's your valves. If the compression goes up, it's the rings.
I adjusted the valves and I was still getting oil on the plugs and in the exhaust plus loss of power when running . I already have the engine mostly apart ( i guess i shouldn't of been so hasty). Is there still a way to tell if the valve or the rings are the problem. maybe by measurement. I also am having a problem getting the cylinder off to get the pistons out of the engine. I only see one bolt and I have both sides of the case off but the thing wont budge.
I think on the 175's there's 2 bolts - front and rear. Not much help on the 200 though.
The best way is re-assemble the motor and give it a compression test. Someone on here described doing a leak test of some sorts to the valves. You might want to try searching for it. But it involved rotating the cam by hand so the valve was shut, pouring oil on the valve stem, and seeing if the oil got through to the combustion chamber.
