CB200 fork rebuild / replacement
Flash
Active Member
Anyone know if a CB175 stanchion will fit the CB200 outers? I'm pretty sure they're the same diameter but I'm wondering if there are other subtle differences? My current stanchions are beyond repair and replacements are getting tricky to find. Do I have any other options?
After a bit more research, it seems I'm out of luck with these things. They don't fit.
Has anyone here fitted better forks to a 175/200? I can't see the sense in buying another set of the same.
I think DCMSpikes actually had some machining done and ended up fitting CB350 forks to his CB175. Might try PM'ing him about it
I have a set of 200 forks that are in pretty good shape if you are interested in buying them.
Cheers,
Kevin
Thanks, lads. I'm figuring that any changes should be for the better or I might as well leave the old ones on. I very much like the idea of finding better forks for better handling: These bikes are slow so my corner speed better be high.
Theyre different forks. I believe the stanchions on the 200 are a few mm larger. I know for certain that they are different forks.
HOWEVER - Im nearly certain that the headtube on both bikes is the same size. That being said, if you could punch a whole tree out of a 200, I think it would bolt right up on the 175.
and with THAT being said - I dont think youll experience much of a performance boost in handling all said and done.
