scirocco25
So I have this CB200 that I need to sort out a front brake for, currently no disc or caliper on there.
I was thinking that if I have to get some new parts, I would just do a drum conversion instead of trying to piece together a crappy mechanical disk setup.
Will the cb350 front wheel bolt up to the cb200 forks without too much work? Or is it easier to swap the forks? Will the cb350 forks fit in the cb200 trees (31mm?) or do I need to swap everything at once?
Is the steering stem on the cb350 the same as the cb200?
Other option would be to put a disk back on the stock cb200 wheel and then custom make a caliper mount for a hydro caliper such as an R1/R6, or something else that would come close to the mounting style of the old mech caliper.
Any ideas?
Any ideas?
