Bert Jan
Holy Modification Batman
So, all is good on the cb200. engine purrs, all lights work perfectly but the front light keeps burning. I made a small difference in the loom. This is what i did.
I made a new switch for the lights and connected the incoming positive of the switch to black wire plug in the loom. The 2 wires coming out (blue and white) are connected to the bulb, as is a ground wire.
When i attach my battery loader (12v 6amp) to the battery connectors on the loom, all is fine.
But when i bump start the bike (no battery and kicker fucked) the headlight snaps as soon as the engine runs. When i switch to main light it goes VERY high for VERY short... Everything else works perfectly and even the small signal lamps (neutral and blinkers) work perfect, even on very (8000+) high revs. Ground wires are ok, as the headlight does work on my battery loader.
I'm going to multimeter the wires for high voltage as that seems the only logical thing to do. I'm in the dark why it's only the headlight giving me the boot, as it's on the same positive black wiring as all other lamps. I removed the on/off light switch. Engine running means lights on.
And yes, im using 12v lamps
What's the problem?
What's the problem?
