Re: cb200 idle problems- basic carb setup
what year is this bike?
first: make sure the throttle opens the slides at the same time. stick your fingers in them if you can an feel it tgether, adjust .
idle speed: starting on #1 side only
1/ turn up the (cable ) throttle screw at the carb til it keeps running.
2/ turn the idle mixture screw out a tiny bit then in till it revs up some more then back it off a little, 1/8
3/turn the throttle screw back down to a very fast idle but not screaming on that side.
turn bike off , pull other plug wire and see if it will run on just that cylinder with the thrrotttel twisted up as necessary.
next - attach the plug wire.
back the #1 throttle screw or adjust it till it runs, higehr revs a little bit ok.
4/turn up the (cable ) throttle screw at the #2 carb til it starts to rev a little more
5/ turn the idle mixture screw out a bit then in till it revs up some more then back it off a little, 1/8
done right this will at least put both carbs in the playing field- OR you will find ine if them is horrible.
my cb450 will bloop, bloop. bloop on #1 but not # 2 no matter what, this is a valve adjustment problem on mine .
either carb adjusted right will run the bike at idle, this is a nice way to set them for a trial setting.
when they are both hooked up, ll you have to do is adjust the throttle stop screw uti it idles ok. the rest of the carb should now work fine OR there is soemthing wrong, but you will know which side.
you may have a sticky , leaky float or needle flooding, anything comeing out of the carb bowl over flow?
thats all for now.
best, bw
