Checked cam timing. Dead on. With rotor on "T" mark, the notch for the advancer is precisely pointing either up or downwards.
While i was working it i touched the right header. Stone cold while i just rode it. Damnit. Left side was very hot. So again, she's running on 1 leg. Pulled the plug and started her. Got more then 1,5 cm of spark between engine and sparkplug, so thats ok.
Checked carb. Clean as hell, float height ok. Jets clean. No leaks by intake manifold. When i spray starterspray into the intake of the carb or around the intake manifold, there is no difference in revs or whatever. Does nothing.
Going to check compression tomorrow. Gave my tester to a friend in need so could not do that tonight.
Pulling the engine out of the frame is next, and check top end. Whilst i just did the top end, my guess is i forgot something or installed something wrong. Could be a bent valve or whatever.
my money is on low/no compression now, as it has a big fat spark but the plug is wet after starting.
The whole 'runs good when cold' is bullshit now i guess. I assume it never rode on both legs, as it performs as good as it ever did in our possesion.
goddamn shitfaced little bugger.
Gonna search for a cr250 engine and call it a day. i so wich that was legal
