Big R said:Flash, you were just joking about buffing those tubes, right? Cuz those pits will chew up any fork seals in about 1 kilometer
Curbcast said:Great info in this thread. You narrate well.
Curbcast said:I have a cb200 as well. Its not a overhaul, so no build thread BUT...
You have the cb175 drum front wheel on that bike yes? I just bought a 175 parts bike & am hoping to swap out the mechanical disk brake in favor for the drum. Is it common knowledge that the cb200 forks fit the 175 drum braking wheel & the cb200 disk setup?
If so neato!
Keep up the great build info!
thompsonmx100 said:Ah weld them up, stiffer suspension improve the performance. ;D Keep it up
Flash said:
- I have bought some shiny bits for the bike but they will be fitted after everyone has finished playing with it. I’m still up in the air about the tank and which one to use. The 200 tank is just plain ugly but every other tank I’ve sat on the frame looks too big. Maybe a the 175 tank is my only option?
Flash said:First up: Experience has shown that the best way to commence any restoration is to get the rolling chassis together asap. Once you can see wheels on the thing, you'll be able to see the light at the end of the tunnel. Until then, it just looks like a pile of parts in the shed that can be easily forgotten.
