CB200 Right side not firing
hecklejk
Hey guys I just posted to the Big Ass Projects section http://dotheton.com/index.php?topic=4769.30 with some of the work I did over the last week, and some concerns that I have about the right side of the engine not getting hot.
When the bike starts, it puffs out a little black smoke from both exhaust pipes, both sides seem to have good compression because when you put your hands over the ends of the pipe you feel equal pressure. The only thing that is different is when you turn the bike off, the right side is as cold as it was before it was started. The left exhaust is hot, and smoking a bit because of the wrap I put on the pipe, but the right side is cold. Any ideas as to what might be causing this to happen? is it a timing issue??
Could be a number of things really. Have you actually checked the compression with a tester yet? Do this soon!
It could also be your just running really rich on one side or lean on the other, it really depends on several key things. Check your plugs, check you air screws, make sure your carbs are synced, could even be a valve needs adjusting. One side isn't equal to the other (obviously), so check the small stuff. Prob just fuel mixture problem, but check your compression first.
Word, thanks for the tips! I was going to check all of these things this week. First thing was to pull the left side plug wire with the bike running and see if it kills the bike (which it should) I dont have a compression tester, so I will need to see if I can rent one or borrow one from Auto Zone or somewhere like that. Did you happen to see the other post, and see the video? I also left a question on there about tire size for you, since I know you are working on the same bike! here is the link just in case http://dotheton.com/index.php?topic=4769.30
Thanks again for the tips.
