cb200 Stator
FEARtheBEARD
Hello my stator on my bike is bad and i was wondering if anyone knows where to find a new one or if i should just get it rewound? i would rather find a new one :)
well i figured it out it wasn't the stator but because i had 3 brake lights so it was pulling to much voltage its weird though the bike only charges itself up to like 11.9 volts, is this a problem?
is this because the regulator wont allow the bike to put out more than that voltage? A.K.A. do i need a new regulator?
So it ended up being my stator, does anyone know where to buy a new or re-wound one I need to get it ASAP I want to ride this bad boy!
http://www.ebay.com/itm/honda-cb200-cb200t-1974-76-stator-and-mounting-cover-05274-/261073264115?pt=Motorcycles_Parts_Accessories&hash=item3cc92dddf3&vxp=mtr
How did you check your stator? If the bike will run without a battery, your stator is good. 11.9 volts on the batteryterminals is enough to have doubts about the regulator, but not enough to say for sure its broken. Could be a false reading due to corroded terminals or wiring plugs with corrosion. On a CB200 there are 3 wires coming from the stator. Yellow, yellow/white and pink. Yellow/white is an overload wich connects into yellow in your headlight for reasons i still don't understand.Edit; i do know now why. white/yellow and yellow are connected when headlight is turned on, thus providing enough piwer for battery loading AND headlight Pink an yellow are your powerwires. Pink goes straight into the recitifier (making DC out of AC) and yellow goes to the regulator aswell as to the rectifier. The regulator (black/yellow/green) controls the amount of volts on the wire and disposes everything above roughly 12v. How much volts are there on the yellow and pink wires BEFORE they enter any of the above mentioned units? You can use a multimeter to check. You'll have to use a multimeter and use the frame as a negative, as they are both AC. The readings must be done with engine running and should be above 12 volts. Don't forget to set your meter in AC mode as it will not read anything in DC mode.
When you've got anything above 12v @3000RPM your stator is ok. Thats really the only way to know for sure. Lesson i want to give you is that you should never assume anything. Its OR good OR broken and there's only one way to check that. Do it that way or not at all. You'll be chasing your tail till... well a long time. Replacing parts is the last resort. When i have electrical issues, 9 out of 10 times it's something stupid like corroded plugs or sum....
I do not want to lecture or offend you (my english is not topnotch so im not sure if it looks that way), but you're the only one @ the bike, so if you're giving us false information, we're gonna give false advice. And you clearly don't want that since you started this topic ;)
Other way to check the stator is connecteing a multimeter to ground and individual wires (yellow/white/yellow and pink) and see if they ground. If so, replace. Thosre wires are not suppost to ground.
