CB200 throttle cable issue
facefirst35
Coast to Coast
I'm at my wit's end and am hoping someone can help. My CB200 is possessed, it seems. I put superbike bars on, so it lowered the bars a couple inches. Seems that now I'm having an issue that when I turn the bars left the RPMs go way high and when I turn it right it dies. The odd thing is that sometimes when I turn it left the RPMs are fine but when I turn it left it still dies or at least the RPMs drop considerably.
I've tried running the cable over the tank mounting point, since that is how it was when I got it, and also under. Neither way seems to help. I've tried mounting the part of the cable where it splits (the housing part) into two, so it is stationary but I'm still having issues. Is there any chance at all that the cable itself could be shot? I've also noticed that when I rev the bike the RPMs seem slow coming back down, which may or not actually be an issue.
Would the lower bars make a difference? Doesn't seem like it's that extreme that I'd need new cables, but who knows.
Turn the handlebars and see how it effects the carbs, if when you turn it left one carb opens then that's your problem etc. you jut need to figure out what's happening, figure out how, and stop it.
Sorry for the crappy response buys e can't diagnose the problem over the Internet only you with your hands on the bike can figure this one out.
Good luck!
when you take the conectons off the carbys do and pull/ move the cable do they both move at the same time? mine were very frayed and i had a issue with the line so i ended up getting a whole new cable online(cmsnl). am yet to see how it goes though.
Not sure on a 200, but on my 350 it goes from the throttle, between the forks, under the tank mount, above the coil then the 2into1 rests in the space under the tank on the right side of the frame (right if you're sitting on it)
The 200 is a bit different as far as routing. So I took out the right side throttle tube because I was gonna reroute it, but then realized it is routed correctly. I put it back in exactly how it was when I took it out and now the idle is fine. I wonder what might have been causing that. I set it at 1500RPM and it stays there no matter how I turn the bars, which is good.
I took it for a spin around the block and I notice that when I hit third gear that if I gun it the bike just whines but doesn't speed up. Basically feels like I've got the clutch squeezed in. Now if I slowly ramp it up it'll speed up gradually. Any idea what that could mean?
That my friend means your clutch is slipping.
What kind of oil are you using?
Try adjusting the clutch like it says in your shop manual
If the adjusting doesn't work per the manual, do yourself a favor and replace the steel plates, friction plates, and clutch springs all at once. I ended up having to do my clutch 3 times (friction plates and springs 1st time - didn't work, steel plates the second time - helped but didn't work perfect, added an extra steel plate to the middle of my clutch stack the third time - fixed the problem). Moral of the story is; if you're going to do something - do it right the first time.
Obviously check all the easy stuff first (adjustment, clutch lever play, make sure you have motorcycle oil designed for a wet clutch and not automotive oil, etc). If that doesn't work you can expect to spend about $100 on new parts. You'll need 5 friction plates, 5 steel plates (A&B), 4 clutch springs, and probably a new right crank case gasket. Snap ring pliers, an impact driver, and torque wrench help get the job done. Good luck!
Thanks for the info guys. The bike only has 1900 miles on it, so it surprises me that I'd have to replace parts. I'll do the adjustments first and hopefully that fixes it. I'll report back.
Yeah - if there's one thing I've learned quickly its to do the easiest stuff first. My CL200 only had 2,300 miles on it when I got it and needed to do the clutch, but I think it was used as a learner bike by the PO's children/grandchildren who undoubtedly fried the clutch plates.
