tnahvu
Vrooom!!
got a problem with starting the electric start motor on my 75 cb200t. hoping for some directions and tips.
Aftermarket electrical components:
Petronix Ignition
Dyna Coil
*i took the bike completely apart 2 months ago for transport and for valve and bore job. finally got it back together now. Everthing worked before.
Problem: lights and all other electrical functions work EXCEPT the starter AND no sparks when the start motor does turn -- only when i put the battery (+) lead directly to starter motor cable (is that considered jumping? --sorry). i've reconnected all wires to the best of my memory (i know, i know) and matching up wires to right color and such.
I read some other threads with somewhat similar problems, but nothing quite like mine. i've tried just crossing the two smaller yellow/red and black wires at the solenoid together but nothing. no clicks. just silence. also, i get the random shorts that burns my fuses.
is the solenoid supposed to be attached to anything else other than the battery (+), starter black cable, and the other four small wires which i'm sure i've reconnected properly. i've tried attaching it to my frame, but still nothing.
can a bad solenoid effect the ignition? how can you tell if it is the solenoid? what else can it be?
anyways, I have a picture to supplement since i know my description might be difficult to understand.
Petronix Ignition
Dyna Coil
