Bert Jan
Holy Modification Batman
I want to know if a cb350 twin cam fits in a cb250 head and if the lobes are higher or not.
I rebuild and engine couple months back on wich the camshaft sprocket was welded on. I had to cut it up and found myself another camshaft.
Now, the problem is that the rocker arms have play, no matter how i turn the rocker arm pin.
How is that possible? To my knowledge, the maximum space between valve and rockerarm is about 0.05 inlet and 0.08 outlet. I'm getting 5mm spaces here with the pins adjusted as much as possible.
Not getting it. anybody chime in?
