CB350 B&B Special
bredenal
Ok I have been a lurker for 2 months not by choice but because I am in Afghanistan ( I am a civilian contractor teaching the Afghan Army NATO weapons) and my bikes are in Chicago. I am coming home in 2 weeks and have big plans for the 350. I am going to plot out the the plans here and I would be very freatful for any feedback. So there will be no pics of the build for at least two weeks but I want to hash out all the details now so that the build goes faster.
Frame
2 options I have the stock frame which will be shaved, braced, welded, and powder coated
or I have the ability to get a 1971 sl350 frame I was wondering if it worth it to go with the stiffer lighter frame.
Swing arm
I have read that the SL350 SA is about 2" longer which I think would improve the handling if anyone has done this I would love to hear your feedback
Sprockets
I am going with sprocket specialists and they said that they can machine them down to a 520 chain and the rear will be aluminum any suggestions on the tooth count
Rear brake
I am keeping the stock 350 hub I looked at many options for this and I have thouhg t about and RD 400 rear disc but I can not justify the need for a rear disc on a 350
Front fork
I am going with a sl350 triple tree for the 35mm fork tube size with cb500f forks and one disc again i can not justfy the need for dual disc on the front I have a 75 CB400f and that stops plenty with a single disc and drum setup I have a 350g front hub for the disc brake. I was wondering if I am goung to have problems putting that hub (axle size)in the 500f forks and if the disc or caliper will be compatible 500f caliper 350g disc
if any on has another sugestions on front forks I am open.
Engine
11.5 to 1 piston set megacycle cam and p&P job on the head. Mikuni 32mm set and if all possible a exhaust of my own building that will ethe head like a CL but then merges at 23" ( there is a formula to determine header length and that is what I shoud keep the headers to) then it will curve into through the frame to the right side and exit through a cone
Electrics
from scratch wiring and as far as the batteries I have a buddy that works for a company that builds battery packs and so he told me that he could make a batery pack that had the punch of a stock one but fit it is your pocket. Electronic ignition also
Name
#52 B&B Special ( I will explain this one when the bike is done )
Cosmetics I have all figured out but that can wait till I have pictures.
If there is any thing that I forgot please tell me.
Here is how the bike sits as of now patiently awaiting a new life.
Thanks for doing what you're doing; a lot of respect in that.
Swing arm
That's something to consider. Dracken1 claims his are 3" longer and they work great. If you have the cash (which i presume you do since you've been in Afghanistan), I'd look at his products. Or RocCity seems to be willing to make bespoke swing arms. I personally cannot stomach the liability exposure.
Sprockets
I personally don't think this is worth the trouble.
Frame
I think the stock frame should be fine. The SL frame is cool, but won't it be a registration nightmare? If not, I say go for it.
Rear brake
Front fork
You're right: a disk (front)/drum (rear) is plenty.
Engine
That's quite the engine. I've not built an exhaust with that cam combo, but I can tell you my specs for the primaries are different than the one you stated. I've been meaning to make a stainless 2-2 CL exhaust, as well as a 2-1 CL style exhaust. And I too have thought about having the cone bend through the frame (sorta ProTeal -style) before exiting through a reverse cone. It would look really cool. The trouble is, you may have black jeans after a ride.
I'd be happy to quote an exhaust pice for you. PM me if you're interested.
--Thanks, Chris
The anticipation is killing me I read all the threads that everyone has on their bikes and I want to tear into this thing so bad. But, I know I will be better off in the long run if I figure it all out now and do not get to a point in the build where I need something and make a rash decision.
I am lookind at some alloy SA and I am not completely decided yet.
I have decided on the SL350 frame it will be different and I like the clean look of the frame.
Sprockets I need ideas on for tooth count the engine will be a little hopped up but notheing crazy I am thinking engine on the dyno at 42-46 has anyone changed out their sprockets and what are they running
I was wondering if there are any free programs out there that can be used to create drilling patterns or is there an easy way to make paterns that can be printed
Does anyone know if a cb350g front hub will fit in cb450 or cb500f front forks I have the sl350 triple tree and so they are 35 mm I just do not know if the axle is smaller on the cb350g than the clamps at the bottem of the 450 or 500f forks also will the cb350g caliper mount on the 450 or 500f forks
I know this all sounds pricey but after building many cars on a budget I am determined to do this bike exactly the way I want. I am selling 3 cars to fund this project a 68 sunroof bug 73 cal look bug and a 48 willys overland pickup I will cry the day they are all gone but i want one thing to focus on so this thread will be a rocking come sept 18th till it is done hopefully may my gilr already has claimed the CB400f for herself so I have to get this done
bredenal said:
Swing arm
I have a 71 sl350 sa mocked up on my 72 cl350... It's more like an inch longer than 2, I'll measure it to give you an exact number. Does make a difference though!!!
Now that sounds interesting. Are you ex-mil? Or bilingual?
thanks for the measurement of the sl SA how does the longer SA affect the shock geometry
I am former military USMC I was a sniper in the Corps and now I teach the M-24 (army sniper rifle) to the Afghan National Army.
is anyone running a sl frame here on a cafe
These guys on this site built a cafe using a cb350 motor in an sl frame. Turned out awesome! They have some good info on there about measurements and such. Hope it helps.
http://niskygarage.logical.net/CB350/project_cb350.html
That site is awesome I had seen those bikes as I was crusing google for cb350 builds but never the build of the bile. What I would do to be able to access some of the machines in my old high school shop class.
From the center of the pivot bolt to the back of the axel plate the SL swingarm is 1 1/4" longer than the CL swing arm. The axle plates are different though so actual wheelbase difference is probably only about an inch. It surprisingly makes a big difference in the appearance of the bike though!!!
72 CL350 swingarm, 19" center of pivot bolt to rear of axle plate.
71 SL350 swingarm, 20 1/4" center of pivot bolt to rear of axle plate.
Hope this helps!!
Thanks for the measurements Marc. I was wondering if you knew the shock length you aer running in the rear with the SL SA.
Right now it just has factory cl shocks, about 12 3/8" I think...
Here's a pic of the ugly beast... I'll work on it someday!! lol
Gives you a idea of the cl frame with the sl arm though...
Pardon my current mess of a garage...
I am also having the tank cunundrum that it seems everyong on this site has. I have days till I am in the garage and wrenching. My garage looks loke that but with old vw and Porsche parts. I am selling off the stable of 3 vws and sticking to wrenching on the 2 bikes. (they take up alot less space) Sorry to bring this up again I was wondering if there were any insights to the question about front forks. I have an 1971 sl350 triple that is 35mm and a cb350g front disc hub will the hub fit into a set of cb500 forks or is there another model that will work. I am not sure if the axel of the cb350g will fit in the cb500 fork clamps.
the girl just did a oil change and tune on my cb400f so I can ride whee i get home anyone from Chicagoland. Wha has the weather been like lately?
I found this link
http://www.chopperfix.com/forums/viewtopic.php?t=218&sid=91a3fc461fea6a0a9fc0c9caa34740f7
It has everything you need to know about front forks tube diameter, axel size, and bearing size the only thing that it is missing is the distance between the forks.
From what I could decipher my Cb350g front hub has a 15mm axle with 33mm forks
now I want to go to a 35mm fork but keep the cb350g hub
from what I read the CB450 Cb500 both have 15mm axles with 35mm tubes
now will the cb450 or 500 front brake caliper work with the 350g hub and disc or will I have to change the hub and if I do that is the space betwween the forks going to change if I use a cb450 or 500 hub
I am using a sl350 triple which is 35mm
if anyong has done a 35mm front fork conversion on a cb350 what is your setup
im running cb450 yokes (triple trees) with cb500t Forks. cb360 front wheel since i did a disk swap.
your issue is the spacing between the forks... its larger with the 35mm forks.
i say take your axle to a machine shop and have them turn you a new one on a lathe thats longer, and also get wider spacers.
