cb350 bogs down around6000 rpm
jonob
Hey guys this is my first post on here ..
Just got given a 72 cb350 and have got her all running except whenever the revs reach around 6000 rpm like highway driving it bogs down.. I have cleaned the carbs and replaced o rings and gaskets except the o rings on the 2 removable jets in the float bowl that hold the little seat for the floats.. The o rings are quite worn and i am wondering if replacing these might stop what seems to be overfuelling or am i barking up the wrong tree entirely??
Anyway i am hoping someone can tell me what to try.
Thanks from newzealand.
Jono
if your carbs aren't 100% in good shape, you're barking up the wrong tree chasing any other symptom, fix the o rings
Cool. Will try model store tomorrow for some small enough o rings.. Petcoxk shoukd be fine as i had to diy make a new rubber seal so now the fuel wont stol flowing even in rhe 'stop ' position haha.. And float biwls were overflowing until i sorted that problem earlier today.. So i definately t
hink its drowning..
Definitely replace the o-rings that ensure the carbs are 1000% clean. Check the petcock screen as mentioned. Ensure the timing is set right.
