CB350 Cafe nearly complete
interceptor
Coast to Coast
Almost done! What the hell am I going to do in all my spare time? I guess ride the damn thing. ;) Or start my next project.
Here's the foot gear selecter I made. Just mounted the foot rest in the passanger postion and built from there. Had a set of CBR rearsets bolted on in the beginning of the build, but they were to flimsy for this application. Had to make something beefier.
Here's my foot brake. I messed up when I made these; I made them a push instead of a pull on the drum brake arm. The original rod was to weak, so I ended up making my own brake 'bar'. I made it out of 1.5" X 3/16" piece of steel. Works great. I also shortened the brake arm (attached to the drum) because the throw was way to long.
Is there clearance for the exhaust with the shifter like that or are you just going straight pipe? Looks good moved back like that. What kind of foot peg is that?
Hey thanks. There is no room. Thinking about making my own, or getting those little shorties and cutting back headers. Don't know yet. If you look at top of this page, there is a cool pic of a bike with shorties. Something like that.
I got my foot pegs at the local bike store (BMX Pegs $12). They were smooth, so I put grip tape on them.
bikeboy said:
nice work fella, but where's the build thread ;)
ian
Yeah, I know. I found this website about a month ago so I never really thought to take pictures of the build. I will get something together as I did take some pictures. Right now I'm nursing a knee injury, so it might take awhile.
you used the shift lever on the brake side... and brake lever on shift side.
color isnt my cup of tea, but its definitely different.
i could be a negative fucker and say everything i dislike, but im just going to say nice job, and it sure as hell would make me look twice if it passed by me on the road. one of those bikes that could probably grow on you.
Yeah, it's ugly as shit. But I did what I did with what I had at the time. I think once I figure out the tank color, it will all come together. I got this bike with a box of extra parts. So I had an extra shifter in that box. (Not original to this bike.) I cut it in half, sized it up and welded it back together. Actually, the part on the shifter that the shifting rod connects to is the piece that I cut off the shifter. So I didn't waste anything. And the original brake was taken off and thrown away. Since I moved the peg position back, I had to make my own. Took the shifter that is original to the bike and made that work on the brake side. (I like to use what I got). That was cut in half too, welded and blended. So I made my shit on the cheap. But it's solid and it works. And it actually works good.
OK, I'm going to start my build thread with the pics I have. Like I said, I didn't find this website until about a month ago, so I didn't take daily pics. But here's what I started with. A 1972 CB350 twin. Not running, parts missing, etc.
So I took the electronics off and started to reassemble with parts I had in the parts box that was given to me. Most everything was there, but I had to figure out how it all went back on. When that was done, I took it all apart, ground all the extra tabs on the frame off, smoothed it in certain areas and then sent the frame and swingarm to get sandblasted and powdercoated. Meanwhile, I tore engine apart to replace seals and gaskets. The pistons were cleaned, cylinders were honed, valves were lapped, and engine cleaned. (Just cleaning the engine took like 2 weeks.) Repainted engine and assembled. Cleaned and rebuilt carbs (or so I thought, but more on that later). Then I had to learn how to do the timing, boy was that fun. Did it wrong the first time, and then had to redo it like 3 times until I figured out what the hell I was doing. But I got it. :D
Here is a pic of bike after some assembly
More pics to come.
