cb350 carb problems!
bikenavy
Hey so I am new to this forum and rebuilding motorcycles and carbs to be honost, but i am having trouble with sinking carbs. I rebuilt the carbs as described in the manual replaced all the jets and gave them a good cleaning. But i can not find anythin that tells you how to sync them, does any one have any good sites or books that have a how to guide in them. im lost and i wanna get this puppy going. thanks again.
i beleive you can buy a gauge carb syncing gauge thing.. or the manual tells u to sync them by going off the air pressure u feel at each exhaust tip.
can find a manual for ur bike here
http://www.repairmanualclub.com/index.php?cid=6
good price on a cymer manual
http://www.clymer.com/Book.aspx?bid=482&title=Honda+250-350cc+Repair+Manual%2c+1964-1974
You will need a carb sync tool like a Morgan Carbtune or some type or mercury manometer. I would stay away from mercury. That's some bad shit! Your carbs will have a screw that you will remove to fit the vacuum tube attachment. (not anywhere near your exhaust tips) I'm not sure exactly where the adjustments for your particular bike are, you will have to consult your Clymer for that. For both of my bike the adjustment is on top of the carbs with a locking nut. When synching your carbs, you'll want to adjust them for the factory spec idle RPM. You will want to sync a warmed up bike. So warm it up, adjust the idle screw until you idle is at factory spec. And see if you can get equal pressure in each carb. It will take some trial and error. When you adjust one carb, another will move. Be patient. It doesn't really matter what the actual vacuum pressure. Your main objective will be to adjust them to the same level. Give it a shot and let us know how it goes.
