cb350 charging
sandman28
how bad is the stock stator ? planning on running H4 headlight, LED tail light (no turn signals but ma add them later). Will be kick only and swapping the battery for antigravity 4 cell and modern Reg/Rec . Is a high output system like the rick's motorsports stator etc "needed"?.. or a worthy upgrade for the $$ ?
Thanks.
thanks, after reading all I can find it seems the 4cell antigravity battery will be fine for kick only... ?
Yea 4 cell is more than enough and will have plenty of power. Even is you add the electric start back it will be fine for the 350's.
You can either upgrade your charging system now, or do it later. The only difference is that when you do it later, it will be because you are stuck at the side of the road with a dead bike. >:(
The stock charging system is so marginal, that any upgrade in lighting puts you on borrowed time.
thanks AlphaDog ... kind of what i was thinking. after removing the starter motor is it simply JUST the flywheel/rotor that gets put back on ???
I'm not sure, but it seems to me that you may need to leave the starter gear and clutch in place, but others who are more familiar with that engine can tell you better than I.
The Rick's unit is just a stator replacement. So the rotor, flywheel, starter clutch and everything else can stay.
Also, you can use just about any regulator/rectifier with the Rick's stator, you don't need theirs.
k thanks. just seeing what CAN be removed. rotor obviously stays ;D didnt know if you could remove the rest of crap needed for elec start
