CB350 Conversion, Project, PITA, etc
DasBalddog
Active Member
Short and sweet,
I purchased a CL350 in June that I had the sole intention of getting running, teaching the lady how to ride and then caff'ing the bike.
Well, we fought with the thing to get it to run well in the late summer/fall, and now winter is here, I'm getting depressed about this bike.
I mean, it runs, but there are a whole myriad of issues that I'll get into, but first I want to make sure its tuned up, ya know, some sort of baseline.
Other than the shop manual, does anyone know of a "How To" on giving this thing a tune up? I'd like to get that done before I start with all the questions.
And here it is, back in the early fall on a day I thought I had it running okay.
http://media.putfile.com/CB350-Electric-Start
I'm thinking of calling the bike "Chimera", or just "Kim" for short, because she is an evil, always changing beast who has given me few moments of piece, and may be the death of me (either riding her, or fixing her)
man it is an old bike. that is why i always take em down and redo them... bike sounded pretty good and it stayed running after you flooded it with gas before letting the oil get around the motor... always let that little guy warm up man, or you will go though a piston. i have the same bike in the shop now... nice glasses
Should be fun to get her looking good. Nice that she runs already, but like Joe said I wouldn't roll the throttle up too much until she's warm.
Actually she was warm at that point.
I am going to take it apart starting tomorrow, but the problem is, in theory, when I rebuild it, the motor will run the same. In theory at least.
There are a few things I was debating the replacement of during the rebuild, the coils and the condenser being two of the ones that I suspect are causing a bit of an issue.
Hmmm.... guess the best thing to do is start tearing the bitch down and cataloging everything....
Question, when I get to the carbs, anyone know if there is a way to check the floats without a float tool? Calipers maybe?
And thanks, the glasses and the jacket were because I was getting to go ride the Gixxer, and wanted to take the video while the CB was still warm.
i would start by adding VW coils, new wires, clean the carbs VERY well, and then get a new rectifier for it. do that before cracking open the motor. may want to set your valves though
You can make a float tool very easy from a piece of plastic like an old credit card. Anything that won't melt when it touches gas. I made one out of a clear piece of plastic one of the kids toys came in. I keep it in my toolbox on the bike. There is a forum post somewhere that explained how, let me see if I can find it.
This is from the 450 DOHC forum, but should apply. The float height is probably different so you should look that up. The principle remains the same.
To check the float height, make yourself a gauge out of one of those junk credit cards that arrive in the mail every few day. Set the float bowl down on it and mark the edge across the narrow dimension of the bowl. You're going to cut INSIDE these marks so the edge of the card will ultimately rest on the edges of the carb body. Scribe a line exactly 2 cm. below the edge of the card - that'll be the float height. Cut a rectangle out of the card (Xacto knife, single-edge razor blade) within the float bowl marks and along the scribed line, then hold the card up to the bottom of the carb and cut away whatever is necessary to clear the jet tower. Hold this under the carb so the bottom of the float rests on the inside edge of that 2cm box and the edge of the card contacts the bottom edge of the carb body on both sides. Turn the fuel tap on. If fuel leaks out, your float level is too high. If no fuel leaks out, lower the card just enough that it doesn't contact the edges of the carb body. If fuel doesn't start to flow out of the float valve, your float level is too low. Adjustment is made by bending the little tab that contacts the needle. Since at least some of the carbs use a needle with a spring loaded float contact, setting the float level with the carb upside down may not work. This is easier, anyway – and it doesn’t require taking the carbs off.. The motor tolerates a setting that's a bit low very well. The level cannot be higher than the 2cm. level.
I'll see if I can get a pic of mine tonight. I just wish mine was a little thicker because it is hard to hold it straight against the bottom of the carb. But, the thicker it is, the harder it is to cut.
Carbs were cleaned, and then put in an ultrasonic back when I first got the bike.
Put a new solid state rectifier in it from Oregon Cycles.
Any details on the VW coils? And is there a particular reason I would pull the motor apart?
And if you mean the tappet valves, did those already as well, though I planned to check them again regardless. (Had to buy tappet valve measurement tools, didn't have any that thin).
@Flugtecknik,
I f you could find that, I'd appreciate it.
naah if it is moving and groooving i would not crack the cases... no weird noises right? i forget what the info on the coils are... i have that info at home somewhere... i can dig it up.
I'd be interested in seeing a pic of that home made tool too Flugtechnik, never heard of doing it that way sounds interesting.
The way I do it is with a clear piece of tube. I get a plastic fitting that connects to the tube and then remove the float bowl drain screw and put this in it. Turn on the tap while holding the tube next to the carb body. This will show you the height of the fuel. Not sure of the height your carbs need to be set at but this method will tell you if you are low or high. If they need adjustment remove the bowl, bend the float tab, then repeat test until you get it within spec.
Hey guys can u post pics of all the carb talk. I know squat about carbs and need to start on mine. Love that there is so many 350 in here someone is always asking my next question. ;D
Well, Imoale, you, HerrDeacon, and WildBill are some of the builds that I am most admiring and some ones before that which convinced me to take this project on in the beginning.
Joe, if you could find that, it'd be great, thanks man.
I'mma start doing this page as an official night hobby. May not get as much done as some people (Imoale, etc) per day, but damnit if I'm not gonna try.
Here's my float level gauge. It is hard to take pics of because it is clear so I tried to reflect the light off of it. If I was going to make another one, I would use some thicker plastic and I would make that little narrow strip wider as it tends to bend.
Alot of great builders in here bro, the BCR site got me started, then Mysta2 pointed me here and man I dig all the knowledge I just found out I paid $20 bucks for a $3 radio shack part LOL... (Rectifier Hint hint) Baby steps Baby steps keep us all posted. Thanks for the pic Flug I'll prob hit u up once it carb rebuild/tune time.
Imoale,
I bought the same rectifier :)
The tear down has begun. This was after I took the seat off.
I removed the carbs, gas tank, mirrors, rear fender, front wheel and fender, exhaust and left foot peg.
Dunno what to do next, any suggestions?
This is at the end of last night.
what to do next really depends on where you want to take this build. I was under the impression that you just wanted to do a tune up, if you are going to cafe it... next project would be the seat....
when i build a bike i always go from the front back on the build.... just easier for me... but i always knock out how the seat will be done so i can sit on it and get a feel for where the build will go as i am continuing along... alot of your work is cut out for you man! someone already did your motor! i would just clean it up a bit and maybe use some touch up paint on spots that need it! someone put alot of time and effort into that bike at one time... i would guess within the last 10 years!
The paint on the motor is peeling/cracking alot on the engine case (down behind the cam chain tensioner).
In short what I wanted to do, now that I realize I have many months before I need her to move again, is basically clean/tidy the whole thing up.
Clean and/or repaint the frame,
Install rearsets and clubman bar (looking into those options now)
Make myself a seat (gonna try my hand at fiberglass)
Repaint the tins (I have a CB tank that I'm going to recondition and install due to I like the size and shape alot better)
Was giving consideration to replacing the coils/condenser (as mentioned before).
Just about every surface needs some cleaning (the wheels are not too pretty and the spokes are fairly rusted)
Need new tires
And one thing I want to do, but not sure how to get it done, what style, price, etc is have new straight pipes bent for it. (I was thinking an awesome idea of running them straight down from the engine, underneath the bike and then doing turnouts right before the rear tire).
I don't want museum quality here, but I want it respectable if I rode it to a gathering.
any muffler shop should be able to do that for you no problem... tuning in a CB350 with cone filters and strait pipes is near impossible though man... does not mean you can not do it... i am going to run strait pipe fish tails with V stacks on my Cb350 bob... i will use lolly pops to assist me in tuning it in... you may want to look into that as well... as far as the pipes, have a local muffler shop knock that out for you, should be pretty easy... running them under the bike is a bit sketchy though cause it is already pretty low... but you will be cool if you just watch it when you pull up into driveways and crap.... i was planning on doing the smae thing on my TX build... but ended up deciding on a diff route... but i still think the turns outs right before the rear would look awesome!
Can you tell me how to check the stock coils to see if they are okay?
I think I am going to tear it down to just the frame and motor, recheck all the motor settings, repaint the headlight bucket and front fender, recheck and reclean the carbs, de-paint/re-paint the second gas tank, do the cafe seat, clubman bars and then it should be pretty squeaky.
I still dunno about the exhaust, the only aftermarket option I can find is the Mac 2-into-1's... and they're running $280, didn't want to drop that kind of coin on just the exhaust. I wonder if I can find some old CL pipes somewhere, tape wrap them and put in the lollipops. The e-bay is coming up scant at the moment.
I went digging though a late 60's and 70's bike salvage yard yesterday to try and find some clubmans or rearsets, no luck. Might have to webbernet those as well.
Anyone know how to test to see if coils are still good?
Also, besides removing the top and middle clamp bolts on the trees, how do I remove the forks? The manual kinda sucks on this particular issue.
Here is where I ended up last night.
Forks pulled, finally....
Rear shocks pulled, and swing arm pulled.
Need a wee bit of help.
When we pulled the right fork, we were using a rubber mallet to pound it down from the top (that thing was STUCK in there).
Well, right at the end, one or two waps from getting it out, there came about 4-6 ounces of black watery liquid.... could this be the fork oil? It flowed like water but was BLACK and was kinda clumpy in areas....
I'm thinking that it might have been water that has been sitting around the fork inside the headlamp holders, possibly from rain or whatever. You can see the black on the plywood where it dripped out.
