CB350 Conversion, Project, PITA, etc
Any help on the coils and figuring out if this black stuff is fork oil or not?
Oh, as for yesterday, Well,
Didn't get much accomplished yesterday.
Baiscally pulled the battery box and looked at how I am going to do the rearsets and other stuff.... pulled a bunch of screws that I am going to need to get replacements for... looking at what I really want to do in this rebuild.
I hate having a budget for this. Would be so much easier with more money :D
Well.
Took the peg mounting bar off. Gonna run just the center stand once I rebuild.
Decided that I'm not going to dismount the motor.
Currently in the process of cleaning the forks, wheels and chain. I'd take pics but its not that exciting. Won't get to the fun stuff until I get it back on wheels.
Anyone have any magical tips on dealing with rusy spokes?
The scope is growing.....
Well,
We've gotten more and more into the cleaning. The forks are fairly well pitted above and below the lower tree clamp. *sad face*
And my girlfriend pointed something out to me last night when I got home. She had started cleaning other parts of the bike and found something unusual on the inside of the rear sprocket.
I'll post a picture in a little bit.
on your spokes, first wash them with SHOUT (the laundry cleaning stuff!) then i was i do, if i am not taking them out of the wheel, i get a micro fiber and cut it into strips... from there you just put on metal polish on the micro fiber run the strip around the spoke and pull it back and forth... kind of like the old stick and string method of starting a fire... takes time but works great!
That's a hell of an idea, Joe.
Thanks.
BTW: Here is the rear rotor/sprocket. Something's wrong here.
ya something is wrong, that is a brake drum... not a sprocket... may have a suzuki rear wheel on there... should not make a diff
Brake drum, sprocket.... Yeah, I don't know the names for things.
I was under the impression that the drum was the outer housing that the spokes are threaded into.
Is there a way to verify whether or not its a Zuk wheel? I would think that it would make a difference when it came to getting brake shoes or tires.
Vintage bikes are like a box of chocolates.........
I found pieces of pine bark mulch in my gas tank and acorns in my exhaust.
no big deal bud, one makes it go... one makes it stop! as long as the drum fits smooth in there and the pads are able to open up, it should not be a problem...
I would guess the entire rear wheel would be from a Suzuki. Like Joe said, it shouldn't matter. It would just require different spacers than a stock wheel, which the previous owner would have already done. Just make sure it is the right size and the spacers keep the chain straight. And, make sure the bearings fit the wheel and the axle and the axle fits the swingarm.
Hmmmm.
I wonder which suzuki it came from then. Going to check the rest of the wheel later for any more information/details.
Okay...
Figured out my misunderstanding of the sprocket/drum thing.
When I was at home for lunch, she showed me the sprocket-side drum cover with the sprocket attached and it was Suzuki. The picture is of the brake-arm side. The center part of the drum and both side covers all are stamped suzuki, so yeah.
Oh well.
The wheel does appear to be legitimately suzuki. There were some markings on the rim (probably a size) but I didn't get a chance to examine further.
Like the way things are going for ya. Theres alot of learning involved in your first build. Good thing is alot of people here are willing to help. I like the idea of keeping the engine in if it iw running and working around it. It will limit a few things thought. I'm thinking of doing that for the Brat style bike, if I get it running first. The wheel thing is no big deal. I'm was looking for possible swaps like that myself to get a smaller wider rim back there. By the way what size is that Suzuki wheel and does it match your front rim?
All I know of the rear wheel right now is that its an 18", and the tire fitted on it is a 4.00
I've been running around crazy today because my last day at my old job is Friday. Going to work for a new company on Monday (I've survived 4 rounds of layoffs at my old company... dunno when my name is coming up, that and new job pays a good bit better)
Happy for you man alot of people out of work. You must be a good worker, thats why your still at your job. Do the same at the new one and they will notice, also dont burn any bridges. That sounds huge!!! Im gonna take a look at your first pics to see how that looks. I want a bigger rear also.
Yeah, I'm actually staying on at my old job part time to help out while they try and find someone to replace me. One of the bigger reasons I haven't been laid off, the job's not one that is easily trained or hired for, but completely necessary for my company. Without me the engineers would have to do their own prototyping... and that's not gonna happen, ha ha ha ha ha.
The standard for the CL/CB350's was an 18x3.5, so whoever crushed a 4.00 on here.... that is IF the wheel is the same dimensions as the Honda wheel. For all I know it could be a 18x4.00 off a GS750 or something.
Picture bro pictures let us see you new stuff. Was looking at jc whitney for the first time sume nice stuff in there like thore pea shooters.
Flugtechnik said:
Here's my float level gauge. It is hard to take pics of because it is clear so I tried to reflect the light off of it. If I was going to make another one, I would use some thicker plastic and I would make that little narrow strip wider as it tends to bend.
that is fucking ingenious.... i say add this one to JRK's $50 mod thread... i would love to make one (properly) for myself.
Pictures soon.
The new job isn't easy on me, coming from my pretty cushy office job. I basically get home, go to the gym, and then go to sleep.
