So this may be a stupid question to some of you out there, however this is my first engine tear down and I want to cross my "t's" and dot my lowercase "j's". Anyway, I seating the Clutch, alternator and gears back into the case when it occurred to me that there might be a slight possibility they have to be placed in at an exact degree. As in the gears or alternator doesn't have some marking on the side where it must line up at a specific point when placed in the case does it?
And I used "#105 motor assembly grease" is it better to be pretty liberal with the stuff or will it restrict oil flow if I apply to much? As I said I put a little too much time into this to do anything wrong. Any help is greatly appreciated!
P.S. What do you guys use to seal the case if anything?
