Madmusk
Hi there. Long time lurker, first time poster. Figured I'd post this problem up here since high quality advice seems to flow freely and I haven't had any luck asking elsewhere.
So, basically my wife's stock 1970 CB350 has been giving me issues with inconsistent firing of the cylinders at idle. I've gone through a long list of possible fixes including rebuilding and cleaning the carbs. All the usual routine maintenance has been completed - valves, etc.
Most recently I checked the spark plug boot resistance. 5.72 ohms and 5.27 ohms. I assume those are close enough to spec but if not please speak up. Then I clipped away some of the old wire to get fresh copper.
Then I put a brand new set of points in, static set the timing/gap to be spot on, and while I was there verified once again that the advance mechanism was acting properly, and that nothing was grounding out. New set of properly gapped plugs, strong battery, stock mixture settings, and fired her up...
Here's a video
Basically, left side didn't want to fire with the choke on while the right would purr away. Turn the choke off and the left side kicks in while the right side starts sputtering and popping. After looking at the plugs (left dry with black carbon, right pretty lean looking though light gray) it would seem the left is running rich and can't handle the choke, while the right is lean and needs the choke. With the air filters off I could see clear backfiring and little puffs through the throat of the right carb with the choke off.
Seems like a clear case of fuel levels right? I don't think a clogged idle passage/jet could cause both cylinders to be so opposite at stock settings. I have the carbs back off but I'm wondering what, besides very carefully setting the floats (which I already did) I can do to make sure the levels end up correct. Both the floats and the needles and seats are new aftermarket parts from the Sirius kit. Should I swap the old float needles and seats back? Do you sometimes just need to keep messing with the floats repeatedly before the levels take?
On my own bike I'm used to setting the float levels with actual gas and a clear tube which gives positive verification that the levels are correct.
Thanks guys.
Here's a video
Thanks guys.
