cb350 electrical problem? how to touble shoot
space pup
Active Member
so i have put it all back together, had it running more or less fine for a while. i had a bit of a flat spot in the carburation at like maybe 1/4 throttle (about 2300 to 2900 rpm), and also was having this problem that it would occasionally just quit, when i was stopped at a light, idling, for no reason at all. sometimes it would do this at home, while tweaking on it in the yard.
so i pulled the carbs to clean them again, to try to get that flat spot out. put them back on and tried to get it to runn smooth.
so it was running, no matter how much i tried to tune the carbs, i was getting inconsistent results. in my opinion, too inconsistent for it to be a carb problem.
so i took it around the block to see what it felt like, and noticed that my flashers stopped working. then later on the flash was working again. then it stopped. then it started again, but running really slowly and at this point i had a hard time getting the bike to run, although it had been sorta runnig well, then, not so, then well again!
i noticed also, that i could see the left plug boot making sparks across an air gap with the cover to the points. i wrapped it in electrical tape to see if i could get that to stop happening, and at first i thought i had stopped, but when i touched the boot while the bike was running, i got a tiny shock. no shock from the right boot, which is a different brand.
so i am thinking that maybe these inconsistent results are due to an electrical issue... poor charging perhaps, and maybe some other problem... coils? stator? rectifier? multiple?
other than changing the spark boot, any suggestions on how to go about tracking down whats going on here?
Start with a battery that you "know" is good. I found that when my battery was dieing, the lights, especially blinkers did some funny stuff.
Then once you know your batt is good and charged, you will need to get yourself a multimeter if you are going to diagnose electrical problems. You don't need a super high grade one.
