cb350 "FORK REPAIR KIT" (?) needed ASAP!!!!
  • Thread starter Thread starter MB
  • Start date Start date
MB
Coast to Coast
So, my frame, engine etc is going to get powdercoated this week, and I may finally have it back after 3 months next week ready to ride, and my guy just informed me I need to do major repairs to my front forks. Apparently I should be able to find a "fork repair kit" with everything I need? Apparently I need springs, seals, "everything", though I'm not sure what that entails. Any advice, merchants recommend? I cant find shit except for the seals?
Ummm... Is he trying to sell you a "fork repair kit"? Because if so hes hustling you. Its pretty rare that the springs actually need replaced on a cb350, unless it has REALLY high miles on it. Replace the seals, use a good modern fluid to refil the forks, and you should be ok.
Nah, he is just a "guy I know that I pay to do things I can't" and that helps me out here and there so I'm sure he's not hustling. I'll check out what is actually wrong with the springs because the bike only has like 12000 miles. Seals and whatever seem no problem, springs seem expensive to source so I don't wanna blow the cash unless necessary..... thanks for the help!
Springs are apparently so shot they can be squeezed down easily with one hand. Weird.
12k is actually a pretty decent number of miles for the 350. Does he have the springs out of the forks? If not, make sure that the fluid level is correct before spending money. If theres no oil (which actually does the dampening) you can easily press forks down by hand. If the seals were leaking that badly, I bet this is the real problem. The springs in a fork (like a strut on your car) are there to soften large impacts, stop the forks from bottoming out and provide the push to allow the fork to return to length. The oil provides the actual resistance and dampening.
scioncb450 said:
what kind of oil do you fill em with??
Fork oil. Your manual (if its an old one) will say that you can use motor oil. DONT...
I like BelRay
Seems like an odd request
Myself? I would do this:
disassemble, clean thoroughly, reassemble with "Leakproof Pro-Molly Fork Seals" (ONLY if they leak)
top off (measure!) with 10w fork oil (5 seams a bit light to me anyway)
ride, make up your own mind
Easiest fix for springs: add spacers
best performance fix: buy expensive progressive rate springs
do you know if you forks leak oil?
If they've been ran dry it's not unfathomable to think the springs are cashed.
Does your dude who fixes things have anything to compare them to?
I have a buddy or two with Hondas but they're avoiding the neverending NY winter right now.....
I'm gonna go over there and do as suggested before I spend $80 from Western Hills.
I should add that last season they were sticking and riding like I had no suspension at all.........They would take a big dive and make a racket on bumby roads (ie most around here) even with full oil. No leaks visible
Well thats no good. Sounds like theyre bad if thats the case. Heres the deal, see if you can find the bits locally as you were planning. If not, I have a set of forks that are beat. Well the chrome is, but they still function correctly. If needed I will wrap em up and send em your way for $50+. Use what ya need from them, and keep the rest as spare bits, or ebay em. Whatever, I need em out of my way.
So also think about this;
Your forks don't have wear bushings like modern forks. If they've been ran dry or exceptionally roughly ridden it's possible for the lower legs to be worn out. Should be able to see scoring on the i.d. Don't know how prevalent it is on Hondas, 'Zukis do it.
Back in the day bent fork tubes got straightened with a press and eyeballs or straightedge. They'd go back together but weren't actually straight. Look for any signs of damage on the tubes.
Same thing with the triples. You can whammy them and still get it back together. Everything needs to line up and slide together.
What I'm saying is that you may have a bind issue. Forks may be cashed now, but that's the result, not the cause of the problem, maybe.
