CB350 Hard Tailed Cafe
dynamitedave
dcclassiccycles.com
This bike started as a complete Cb350. I wanted to put a mono shock on the rear of it that I had off of a SV650. The angle wouldn't work right and there just wasn't enough room around the front of the swing arm so I removed the shock and made it a hard tail.
I wanted the cafe look for this bike. I welded in a support bar to hold up the seat, smoothed out the frame seams and welded them up to give it a clean look. I welded the swing arm in place by welding braces to the frame and I also welded the uptubes from the frame directly to the swing arm.
I cut Styrofoam and shaped into a cafe style seat, covered the Styrofoam with tin foil and laid a few layers of fiberglass. Then applied a thin layer of bondo to smooth it all out and painted it. I chipped the Styrofoam out of the hump and mounted it on the bike. Under the bump is where the battery, voltage regulator, rectifier and starter solenoid are. I rewired the whole bike with just the wires needed and ran the wires where they could not be seen.
I mounted the clubman style handlebars under the top triple tree. I had to cut the handlebar, angle it to clear the forks. I welded in a bung to fill in the void I made when cutting and angling the bars. They are low. Might be uncomfortable but they look cool. I also customized the bracket that holds the speedometer and tachometer and welded the bracket to the handle bar under the top triple tree.
I mounted mufflers from a Harley Davidson Street Bob. They are long, heavy and sweet looking. Since the frame is a hard tail I made a bracket that holds the rear of the mufflers stable. They go through the rear axle and are secured to the muffler with a large hose clamp.
I finally got the last couple of parts I needed and put all of them on and took it for a spin today. It's awesome, feels good, handles good, has a very aggressive stance. I didn't go far, just around my neighborhood but it was fun.
thats pretty cool. one thing though: are you worried about the seat section bending if you hit a pretty good bump? that would be my only concern but other than that its real cool scoot and def unique. good job
I know that it isn't a big bike, but even a monoshock conversion requires beefing up the swing arm, and that is without limiting swing arm movement. I'd certainly want some reinforcement since the swinger isn't designed for the static tension that will be applied with the pivot welded. That one little tube down each side wasn't designed to flex like that. IMO it would be more aesthetically pleasing with the reinforcements as well, if for no other reason than it looks sturdier.
Random pic off the web for reference.
All in all a grovy idea and I really like the bike, its just kinda scary. Sorry to be so blunt.
I agree. Area where the swingarm tubes meet the frame will experience a lot of flexing once the rider is on top and going over road bumps. All that shock and vibration has to go somewhere and a lot of it will end up there. The fixed swingarm will inevitably fatigue, crack and break.
Yeah, I don't think that the rear frame will last very long. I usually don't comment on people's designs, and I hate to bust any bubbles, but that that thing looks dangerous.
CC
I am aware of the swing arm needing more support. I do plan to add reinforcement but it won't look anything like that mess in the picture above. I painted this bike 3 different shades of orange before I settled on this one, now I can't remember which one I finally picked.
I build my bikes to look cool and they hardly ever get ridden. If they do it's just around my neighborhood by me and my friends. I'll fix it, no worries.
Dave,
With all due respect, that bike is unsafe at any speed. The swingarm is not designed to carry forces that way and will most likely bend. The seat arrangement has removed what little strength there was in the stock frame and will now flex in all planes.
Bikes are cool. They don't need to be made unsafe to make them more cool. That's not cool IMHO.
this is just a bad idea. you will get hurt with this set up. there is a reason cafe bikes always have rear suspension. A big enough bump in a corner and you are in serious trouble.
if oyu don't understand physics or how to execute them... or you do and choose to make unsafe vehicles... maybe you should stay out of the frame work. Incidentally, that 'mess in the pic' above was a swingarm i did, and that was in process . the final result was here:
keep in mind, when that arm on the CB breaks.. and it will..... its gonna be 2 tons of suck. Brace it before you hurt yourself or, before it gets sold and somebody else hurts themselves. I've broken a frame at about 80 mph and its scary as hell. (different bike, stock frame let go)
My rd above with the 'offending' swingarm is very stable over 100 MPH.
-mark
I'm glad you posted M. I found the pic from google images, and wondered what bike it was off of. Very nicely done.
building shit like that is just going to make it harder for people to modify there bikes in the future. YOU WILL GET HURT, at any speed it is unsafe! And dont diss people who actually do proper work.
I would be more concerned about my safety than what colour orange you used.
you can allways buy more paint.
Dont mean to jump on the badwagon here, but that bike is an accident waiting to happen. Riding it at 15mph in a circle around a parking lot is in no way proof that it isnt.
Heres to hoping you dont get hurt, and if you do sell it, who ever buys it has the sense to fix it.
God man just weld a couple of bars from the top or your frame to the end of the swing arm and make it safe. It would look so much better and you are clearly capable of it. A hardtail cafe is a very neat concept but it should be done somewhat correctly. Even better cut off the swingarm alltogether and weld up a proper rigid rear end.
