I'm not sure what you mean by wiggle.
But the clutch basket is connected via gears to the crank, and those gears aren't an absolutely perfect mesh. So it will be able to move a bit, but once its under power everything holds together from the force, if that makes any sense...
The clutch basket isnt held on with anyting but the oil pump at that stage, so a little play is probably normal.
