CB350 motor rebuild
JRK5892
Over 1,000 Posts
hey guys, decided to say screw it and i am going to rebuild the top end of my CB350 motor, i have never done this before... any special tools i will have to buy, anything i should look out for or do while i am in there. i know the cam chain tensioner need to be replaced. anything else? it is a 73 cb350 Twin
Yeh I'm in the same boat basically. I just did a compression check on my 73 350cb.The results indicate worn rings and possibly bore on the left head. I have had this bike for 9yrs, it ran for two and then, bam. It has sat since,indoors luckily. It has only 10500 miles on it. Now, I have a garage and the proper tools. Any suggestions,tips, etc...
If you're going to source out the valve head cleaning and cylinder honing, the only special tool you'll need is a torque wrench for reassembly. A razor blade scraper makes it easier to get the old gasket material off.
Im also in the same boat fellas. When I worked on VWs there was a ton of "how to" books on engine mods/rebuilds. Does anyone know of any for the 350s?
VonYinzer said:
I have the manual. I was talking about a performance related rebuild book. Not just a repair manual.
Yep I have the manual. The job in itself seems a bit intimidating. Never done a complete overhaul...
There is no 'idiots guide' for CB350's or just about any other bike I can think of.
Tuning/performance guides, only bike I know has them is the Yamaha XS650 (two books out on performance related stuff)
It's all basic mechanics, slightly more complicated than a piston port two stroke but it sure as hll ain't rocket science (easy to screw something up if you don't use common sense though.)
You probably don't want to send cylinder head out for reconditioning but if you dont have correct tools you won't be able to DIY. :(
You can remove valves and clean them but if seats need re-cutting a decent valve seat cutter set is over $800.00 (NEWAY) or $150~200.00 each for individual cutters, pilots extra. (check eBay :o) Just lapping valves is liable to cause more problems than it solves (cupped valve faces, satts too wide, etc)
Boring bar, about $3,500~$8,000 although you can bore on a vertical mill (Bridgeport or similar) still ned a ridgid hone to finish size ($125~$500, the three lag glaze busters are worthless for precision honing) plus a flex hone for cross hatch (relatively cheap, $20~$40, depnding on size and quality)
Apart form the costs involved for machinery, the skills to use it are also disappearing
I've taught motorcycle 'machining' to a several thousand people but only one or two actually want to do this stuff
PJ
You want faster either pay someone who knows or buy a bigger bike
PJ
Well Pj, I dont think anyones trying to build a "fast" bike as much as there trying to pull a bit more out of the little 350. There was a time im sure bfore thousands of $$$$ worth of tools when guys did cool stuff with thesese motors.
Problem with hopping up old motors is diminishing returns. Sure some expert race mechanics can squeeze close to 50 hp out of a 350 twin but it costs several thousand dollars and is only useful on the track.
No problem with getting a 'bit more', after all, look at the dumb stuff I'm doing to CB360 ;)
When mine's done, I expect it to have same performance as a worn 125cc GP bike (about 40~42bhp)
When they were new the motors were built to a certain specification.
Unless you have very low miles on motor it will be showing signs of bedding in/wearing out (by 10,000miles it definitly needs work if you expect any performance improvement)
Most gains are going to come from cylinder head, (porting and 3 angle valve job, stock ports ae very 'nasty')
Its always been expensive to do it properly (which is why I made my first valve seat cutter in 1977~78)
Way back when, the bike was just for hacking around, cheap to run, reliable, etc.
It was always getting eaten alive by 175/250 twostrokes, couldn't even get close to a 350 stroker
The sort of performance thats now easily available (although still lower than a 'stroker') is due in part to expensive equipment.
If you intend to do any porting it can be done relativly cheap.
carbide burrs from ENCO, about $40~$50 (get 6" long 'teardrop', 1/4", 3/8")
Electric die grinder (Harbor Freight) about $40.00
Router speed contoller (Harbor Freight) about $17~$20 (you really need it)
'Tootsie rolls' (coiled aluminium oxide) with mandrel, (Harbor Freight) about $7.00
You can then carve away :D
When your done, get 3 angle valve job, single 45 degree isnt doing anything for performance (and 5 or 7 angle is waste of money)
PJ
PJ
PJ
Well, this went a bit further than expected. Thanks bud.
nice! well i do not want any more power, jsut put back to clean stock set up... that is all, it is a 350 and will not ever be a ripper, just a cool little bar hopper is all i am building, just want it clean and reliable.
I met a guy who big bored his 350 to 425. He used a pair of CB450 carbs and claimed 1/4 speeds of 90+ mph. Didn't doubt him, he pulled a little wheelie as he left.
I'd send the head out to get the valves / seats faced. These bikes are pretty popular in post classic racing around the world, so you should be able to find a decent machine shop that can do this (it's pretty basic work for a machine shop). You'll need a valve spring compressor to get the valves out (it's less labour / cheaper if you take the head with the valves out).
Check the bore / pistons and if they are in spec, a light hone and new rings should do it. And a new seal behind the points cover as DrJ said.
I'm pretty sure it wont go to 425cc?
I think that needs 76mm pistons.
I tried with 75mm but the bore has to be offset outwards and backwards or forwards a bit to fit inside cylinder studs because they ar not in a 'square' pattern. (still have messed up top case and cylinder somewhere)
70mm is do-able though.
PJ
Haven't opened it up yet. But, on one side there is bad compression. Pored a tablespoon of oil into the head and it improved. Had the bike running a year ago and it gave us alot of white smoke on the bad side...A crack maybe a hole in the piston?
More likely worn or broken piston rings. It would take a lot to blow a hole in that piston.
