CB350 Piston (total motor?) upgrade
Seattle_Coug
Anyone on here running the Todd Henning CB350 pistons?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=260401950803&ih=016&sspagename=STORE:PROMOBOX:NEWLIST&category=35595&viewitem=#ht_500wt_1061
1. Did your stock carbs suffice with rejetting, or did you need to move up?
2. Any headaches to look out for?
3. I'm assuming the stock crank and rods are more than capable of handling the additional power, anyone know any differently?
4. I'd really like to stick with stock cams so I don't have to delve (read: put money) into the head, except to ensure its in fine working order, has anyone else bothered to try this or has everyone else just said the hell with it and stuck big lumpy cams in?
This will be my winter project, but I'd like to start stockpiling the parts so I don't have to sit on a bunch of money staring me in the face (and also so I can't chicken out and just leave the bike alone - its in good running condition but could use the attention), and also so I can keep the excitement building while waiting for deliveries.
Check out this thread: http://dotheton.com/index.php?topic=2057.msg15498#msg15498
I had used an older version of Henning's pistons. I would not spend that much on those pistons unless you were going with a cam, head work, exhaust, carbs, etc, etc. I have used GPZ750 pistons and Powroll pistons successfully. There are definitely some decent options for the 350 without spending big bucks. Do some research - you'll be glad you did.
do the 750 pistons bump up compression?
The Todd Henning pistons are great- If your racing them. Theyre just not built for street use, and youll have to push the timing back like hell so that you can run pump fuel.
I mean- if you do a big cam nice springs head work etc etc, and want to run it on the street, be my guest.
But really, its not worth it. The extra power isnt worth the lower reliability, and you would benefit more from lightening up the bike.
Roustabout, thanks for pointing me towards the thread - has answered a bit of my questions, and i had not yet considered the reliability (must have been too obvious to think about ;)), which is a major point. (FYI to anyone looking at this, as of 05/2009 it looks like Powroll (from their website) no longer produces any parts for the CB350 and various other vintage CBs)
Rocan, lightening the bike is certainly in the plans, but its much easier for me to see what I can remove and drill holes in by eye, and I'm still learning about these motors. Rough comparitave estimate (based on same stroke, additional bore) would put it around 11:1.
I'm not sure you'd have to push the timing as far back as you're insinuating, I've seen mention in a few other places of people running various higher compression options with pump without issue, and have numerous friends doing it with their cars with no ill effects. Certainly you need to be more precise with the tune, but I'm not convinced (yet) its not doable. Valves are also now on my list, I've seen too many references to valves floating and heat-welding to continue avoiding this.
I've settled on GPZ pistons ($60 for a set of 4 with perfect rings and pins was irresistable, and not enough to make me worry too much if it doesnt work out). Ultimately, my goal is to keep it pretty streetable. I've no problem dealing with increased wear rate, so long as it doesnt disintegrate every couple hundred miles. I'm figuring I should still be able to run pump, albeit premium (this does not bother me in the slightest, as its already what I run in there).
crazypj said:
Rokon is the instant expert which is why he got upset at Caferacer.net
Your pretty safe ignoring whatever he says, doubt he ( like most people here) have ever seen Hennings pistons outside of internet pictures
I've actually done dozens , if not hundreds of big bore 'kits'.
I still have a 391cc CJ250T which has done over 3,000 miles at up to 11,000rpm, (122mph, road test 250 @70.4mph)
Stock cam and valves, 28mm Mikuni's, ported a bit, road legal
Its also been on British TV with me riding it.
Two 378cc CB360's, sold a couple of 378cc kits and have enough parts for at least 3 more. (plus parts for 437cc CB360)
Yamaha XS650's, at 653cc, 800cc, 860cc.
Will probably do a 535cc kit in CB350F when I get to it.
Done a lot of CB350'twins with various pistons and different capacities, usually not over 362cc though as thats capacity limit.
It isnt possible to bore them to 74mm, but, 70mm is ok. 68mm is easy
Personally, I wouldn't use Powerol pistons in CB350, even if still available.
They had way too much pin offset in my opinion.
I was real disappointed with power output as well, 33.5bhp@11,500rpm, with Mikuni's and 'race' exhaust.
But, it was what the guy supplied and wanted fitted so he got all it was possible to get from it
Your valve float statement, valve float is around 11,500 to 12,000 rpm, prevents you breaking stuff
PJ
i got upset at caferacer because, for lack of a nicer word, "guys" like you seem to have nothing better to do with your lives then to say negative things.
And just for the record, i didnt say anything incorrect in my post.
if you want to run full race pistons on a streetbike, be my guest.
Thanks for the link, looks like thats exactly what I need.
As to the little pissing match going on, take it (at least that part) somewhere else. I dont like some of the people I work with, but that doesnt mean I try to cut them down every time they say something. I've worked with people like that, and its no more fun to see typed online than listen to in person. The best part of this board is its lack thereof, so drop it.
