cb350 question
Adamcj
Alrighty been snooping around for awhile but have yet to post so here it goes. This is my first bike build and I have a lot to learn. I have a 1971 CB350.
1) Do I need upgraded carbs? I plan on running pods, custom exhuast, and a megacycle cam. Do these items justify upgrading over stock carbs?
2) Since this is a full resoration what is a good order to follow? EX: rebuild engine, paint frame, have little pieces powder coated....
3) What is the best way to tackle redoing all the electrical? How to shed unneeded wires and such?
I'm sure I will have more questions but I will start with these for now.
Thanks!
EDIT: Also I want to redo all the little things that break down over time. IE: bushings, bearings, brakes, cables. Does anyone have a good list of items I should start picking up for this?
Thanks!
1.) Possibly, but probably not. You're not likely to gain a lot from new carbs other than tuning ability, which can be important. This also depends on the type of carbs on the bike. I can't remember which years, if any, have the CV carbs, but slide carbs will probably work better with your upgrade plans. VM28s are a good choice for that bike and those upgrades, but VM30s will work, too (though not as well).
2.) Get everything taken apart and cleaned up, then reassemble. Usually I get all of the body work off, then the electrics, then the engine. After that, stuff like bars and wheels. It should make more sense as you do it. There is logic order, but it's not a hard and fast rule, per se.
3.) Read over the Electrical 101 and Electrical DIY posts in the Electrical section on the board. This should cover the basics and if you have and specific questions, hit us up and we'll cover it as needed.
Decide what you want as far as a design goes first. If you are going to cut tabs off the frame, or keeping the bike original, it helps to know before you start.
Pictures and tape with labels are your best friend. The plus side is a 350 is most common, so even the lesser experienced builder can get themselves out of a jam with ease.
Take apart in big pieces if possible, i.e - engine as awhole, separate the front end from the frame as a whole. When I took apart my 360, I left all the controls, cables, bars, headlight all together on the trees. This kept my work space organized until the time comes for me to work with those items. This way you don't loose hardware and such. When you are ready to tackle the individual sections of the bike, you don't have other parts laying about to get mixed up with. My point is you can get the frame cleaned up without exploding the front end. Once the frame is ready for reassembly, then you can break down the front, engine, what have you.
Taking EVERY nut and bolt apart all at once with prove problematic come reassembly.
Take a look at the top of the carbs. If there is a cable going into the top of each one you have the slide carbs. If there is a chome dome, you have CVs.
These are the slide carbs:
These are the CVs:
Since you're planning mods to your engine and you seem a bit new at this, I highly recommend reading through this thread:
http://www.dotheton.com/forum/index.php?topic=39814.0
Alrighty, I have CV's then might have to look into getting some slide carbs then. Thanks for the help guys, exactly what I was looking for!
Those CV carbs I have found to be very forgiving. For example I'm running a 3mm overbore, Early SL cam, Velocity stacks and a 2 - 1 with a straight through baffle and at my elevation here in Cleveland, OH the stock jetting worked perfect. I messed with round slides for awhile and my experience was that at aggressive throttle they were great but just to seem to not do as well in the stop and go commuter traffic that I am often in. I'd start with what you have and go from there. No need to through fist fulls of cash at it to fix a problem that you may not have.
As far as electrical goes, it gets easier once you wrap your head around it. Approach it by circuit. Start with the charging system and build it up from there adding each circuit as you go. Ignition, lights, turn signals, however you plan to do it. Once you learn the honda color codes it gets a lot easier.
You may find this handy too. Not, you may not have some of these wires. The chart pertains to most hondas of that era.
That's perfect, thank you! Yea I think I'll just rebuild the carbs I have and give it a shot. If they aren't what I'm looking for I'll just pick up a pair of VM28's. And the electrical I'll just have to dive into it and take my time.
Thanks again
Unless you're doing some real engine mods, the stock carbs are fine. If you're running pods, buy good ones (K&N or the like) not cheap Emgos. When you say custom exhaust, what do you mean by that? The megacycle cam isn't a real pure performance mod per se. Its am upgrade for sure, and you'll need to tune the carbs for it but its not like building a race motor.
As far as the rest...
Pull it apart, label everything, and take lots of pics as you disassemble the bike. You'll want to focus on one section at a time. Plan ahead and work in an organized fashion. Don't paint/powder anything until you KNOW it'll all go back together the way you want it.
Once everything is painted/powdered/finished (including the motor being rebuilt and FINISHED) I like to build a roller. Frame, suspension, wheels. Get it all dialed in as much as possible. Than mount the motor amd drive chain. Next I do the small parts like rearsets, exhaust, fenders, lighting, etc. Basically build from the inside out. Than wire. The 350 is a really simple bike to wire from scratch if you plan it out ahead of time. Place all of your electrical components in there final spot and lay out your harness. Go one wire at a time amd you'll be able to hide the majority of it. Than seat and bodywork.
That's a really short version of the process but I think you'll get what I'm saying. Again, its just how I like doing it. Everyone has their own system, but that always worked for me. It also takes a little longer (especially the wiring) but in the end it allows you to really fine tune how everything goes together.
Another really important thing to remember is that you have to keep your parts well organized akd make sure you have everything you need before you begin reassembly. No plan will go without an audible or two, but the base of your build should lying right in front of you before you bolt anything back together.
