CB350 Serial Number Location?
overdraft
Coast to Coast
Hey, does anyone know if the serial number on a CB350 is anywhere else in addition to the sticker on the headstock? I'm considering powdercoating my frame but I don't see how to preserve that sticker and I don't want to get stuck without a way of identifying the bike as registered and mine!
Thanks!
Should be stamped in the frame on the other side of the headstock opposite of the data plate.
CC
You can remove the VIN. Drill out the rivets, then carefully work a thin blade underneath to loosen the glue. Try a solvent like Varsol do dissolve the glue or a hairdryer to warm it up. Reinstall with a rivet gun or tap the holes and use 2 small bolts.
