thanks man! mind you, it was more badass a week ago before it decided not to run properlyjerryz said:This is one badass bike!!! What size tires you running on this?
overdraft said:ok, swapped the carbs... the problem stayed on the right side.... swapped the coils... the problem stayed on the right side... so what are we left with? right cylinder backfires through the pipe and carb at medium low speed, doesn't run at all at idle, but does run at mid or larger throttle opening without issue...
arghhhhhhh!!!!
ya, I'd buy that and be patient if it hadn't immediately worked and worked well... you have to remember the frustration comes not from the fact that it doesn't work, but from the fact that it worked flawlessly for a month and a half and THEN mysteriously fucked up...axeugene27 said:Id reinstall the points ignition and set it up and see if you still have issue. Sorry to hear about the problems man but you got to keep it in perspective you just got the thing together you are gonna have some issues to iron out plus even though it looks new it's 40 yrs old give the old girl a break she is trying to knock the dust off.... good luck bud.
