I have a 71 CB350k Twin that when it gets warmed up it smokes from the breather pipe that vents the crankcase. I have just taken the engine apart and replaced all the gaskets, I have checked to make sure the top is oiling and the compression checks out at over 160lbs. On the advice of others I changed the oil just in case I had left the petcock open and fuel fouled the oil. I have double checked the timing, points and plug gaps. I don't think the engine is running hot because it starts back to easy after shutoff once its fully warn. No other bike I own has this symptom and since this is the only twin I own I have to ask "Is this normal?"
Thanks
Thanks
