CB350 spark or no spark?
Austin
I've been scouring the internets for the past couple days trying to find a definitive answer to a simple question, and I've failed.
So the question,
Can a CB350 start and run without a battery?
So, does the alternator, without the use of a battery, make enough power during a kick-start to create a spark at the spark plug sufficient to run the thing?
I'm sure this has been discussed before, but I can't seem to find the answer in all these threads.
Ok, thank you!
And to go battery-less, I've read you can use a capacitor. How could you use a capacitor if it discharges so quickly (in only a few sparks), requiring you to charge it back up for another go? How would you even charge it in the first place (assuming the bike doesn't start first kick every time)?
There's a guy in this thread. Post 7 and 8.
http://www.hondatwins.net/forums/50-electrical-discussion/11244-running-cb350-without-battery.html
If the stock alternator doesn't make enough power to create spark at such slow engine speeds, how is it possible then for a capacitor to be an effective method for starting the bike?
Then there's this guy who apparently has no battery hooked up (judging by the title of the video)
https://www.youtube.com/watch?v=FcUdkDlqxUY
Why is there such a variety of "answers"?
Because there are a lot of factors involved.
If your stator and rotor are in good health, and you have a good regulator and rectifier (or combo unit), and you're using aftermarket ignition coils, and you have a switch to kill all of the lights, then you might be able to use a capacitor.
