cb350 starter clutch oiling
rockcitycafe
I make things.
does anyone know how the starter clutch and gear are oiled on the cb350? I found a return passage at the bottom of the left case, but I can't tell where the incoming oil passage is
there is a 'hole' at bottom of inner case , it's open to engine oil.
If you start engine with generator cover off you'll see how much oil gets into starter clutch (a lot :D)
What problem are you having?
PJ
