CB350 stator wires with Ricks regulator/rectifier
ducatiboy
DTT BOTM WINNER
I'm rebuilding a 1970 CB350 and I'm completely rewiring everything on it. In addition I have one of Rick's combined regulator/rectifier units to replace the original separate regulator and rectifier.
The original wiring coming out of the stator has 2 yellow wires and one red wire (plus a red/green for the neutral light). Rick's R/R has 3 white wires to connect to the stator. Am I assuming correctly that it does not matter which of the white R/R wires goes to which red and yellow stator wires?
Thx for your help :)
I think your assumption is correct
You bought the combo-kit right? http://www.amazon.com/Ricks-Motorsport-Electric-High-Output-99-101/dp/B0013LF1U4
or just the R/R?
If you bought the combo kit:
The yellow wires are just opposite ends of the single phase stator, so it doesn't matter which is hooked up to which on the rectifier/regulator.
I have the same system, and if i recall, all this is explained in the instructions :P All snarky-ness aside, your R/R should have 2 white wires, and a red and a green. The red and green are to the battery, the white go to the stator.
You'll need to keep neutral red/green wire from the harness and hook that back up to your neutral indicator. Initially this was bundled in with the same connector as the original stator wires.
